 stuck crank gear
downwiththeRB
PostSubject: stuck crank gear   Thu Apr 12, 2012 1:10 pm
Hey im trying to replace my oil pump and i can get the dam grank timing gear off i need help i used pullers i drilled holes and tapped them for puller didnt work i heated it up didnt work what can i do i need this off asap???? its on a rb20det
PostSubject: Re: stuck crank gear   Thu Apr 12, 2012 1:50 pm
The good news is I have a spare crank pulley if you destroy that one. I always used a 2 jaw puller with no trouble (fortunately for me anyway)
downwiththeRB
PostSubject: Re: stuck crank gear   Thu Apr 12, 2012 2:13 pm
i just pmed u
PostSubject: Re: stuck crank gear   Thu Apr 12, 2012 2:14 pm
Sorry I misread. Are you talking about the crank pulley or the timing gear? I have a spare crank pulley. You are going to have to split the timing gear with a cold chisel and replace it, that's a very common problem.
downwiththeRB
PostSubject: Re: stuck crank gear   Thu Apr 12, 2012 3:24 pm
whats a cold chisel never heard of that
PostSubject: Re: stuck crank gear   Thu Apr 12, 2012 3:29 pm
It's in here somewhere. [You must be registered and logged in to see this link.]
That comes up somewhat frequently.
stuck crank gear
