 ka24e to ka24de
JasonAldana
PostSubject: ka24e to ka24de   Mon Apr 16, 2012 9:07 pm
i have a 1990 240 with a single cam. and im looking at a 91 240. mainly for the engine. want a dohc what would be needed for the swap.?
PostSubject: Re: ka24e to ka24de   Mon Apr 16, 2012 9:12 pm
here is a link to a write up on this topic next time look in the stickies for information.
JasonAldana
PostSubject: Re: ka24e to ka24de   Wed Apr 18, 2012 7:08 am
thanks man, ill be sure to search it before i post next time.
PostSubject: Re: ka24e to ka24de   Wed Apr 18, 2012 6:47 pm
trans are the same, clutch and flywheel are the same. All you honestly need to do this swap is an s13 ka24de, wiring harness, both p/s lines, ka24de coil, ka24de p/s reservoir and a new coil to dizzy wire. Its super easy to do. Only difficult part is repinning the plug at the end of the engine harness to the cluster.
PostSubject: Re: ka24e to ka24de   Tue May 15, 2012 9:27 am
youll also need the maf the ecu and the tach from a dual cam cluster.
PostSubject: Re: ka24e to ka24de   Tue May 15, 2012 10:15 am
Tach isnt 100% necessary, but your rite about the ecu and maf. But if your picking out a running motor, you usually get those with it.
ka24e to ka24de
