 alternator question
ttallin
PostSubject: alternator question   Tue Jun 12, 2012 3:12 pm
ok so i have one wire from my ignition running to a relay and the relay turns the car on. do i need the starter wire from the engine harness hooked up for the alternator to charge?? if so can i splice in to them both and run one to the starter, or run the wire from the harness to power??
ttallin
PostSubject: Re: alternator question   Fri Jun 29, 2012 8:29 pm
ok so i researched found some stuff tried to hook the white/black from the plug to the starter and the white/red to a resistor then to power??? but thats not working trying to figure this out before the meet anyone please hit me up 920-342-2392 drinks on me or whatever if i can get a lil hand
ttallin
PostSubject: Re: alternator question   Fri Jun 29, 2012 9:03 pm
[You must be registered and logged in to see this link.] this seem right??? i dont have a dash or indicator light....
PostSubject: Re: alternator question   Mon Jul 16, 2012 3:38 pm
Sorry, just saw this.
The diagram looks right, did you get it figured out?
alternator question
