 s13 sr20det harness wiring diagram
PostSubject: s13 sr20det harness wiring diagram   Wed Jun 13, 2012 9:36 pm
Looking for an sr wiring diagram. Engine and trans, IN ENGLISH, and something i can read. id prefer it to be a pdf file. But rite now im willing to take anything i can read thats correct. Its gotta have wire colors as well since Im shooting in the dark with the shit i have. If you have something then please oh please post that shit up or pm me and ill send you my personal e-mail to send it to.
Before you tell me to hit up zilvia or google you can save it because both of those sites are worthless for sr diagrams. And ive been searching the last 3 days to verify this harness i have. But the car doesnt start. Plus what the fuck is a C.O.P.? No its not coil over plug
ttallin
PostSubject: Re: s13 sr20det harness wiring diagram   Wed Jun 13, 2012 9:49 pm
ahh man harness being a bitch or what??
PostSubject: Re: s13 sr20det harness wiring diagram   Wed Jun 13, 2012 10:02 pm
it wasnt at first, but theres a couple wires that are labled and confusing the fuck out of me. So im just looking for a diagram that i can blow up huge turn into wall paper to verify i have everything in the rite spot. But it seems like everything i find is either in japanese or blurred so bad that i cant read it.
PostSubject: Re: s13 sr20det harness wiring diagram   Thu Jun 14, 2012 6:10 am
They're in a sticky at the top of the tech section.
PostSubject: Re: s13 sr20det harness wiring diagram   Thu Jun 14, 2012 5:05 pm
This is what I used to trace out my harness issues. Maybe it will help you.
PostSubject: Re: s13 sr20det harness wiring diagram   Thu Jun 14, 2012 5:33 pm
^ 404 not found for the S13 SR.
PostSubject: Re: s13 sr20det harness wiring diagram   Thu Jun 14, 2012 9:28 pm
ya not found. You wouldve gotten a free hooker on me delivered if the links worked.
Oh i know theres stickies on these, but they are either in japanese (im not japanese nor can i read japanese), or only half of what im looking for. I found a pretty good link im working off of rite now, but it doesnt show wire colors unfortunately.
PostSubject: Re: s13 sr20det harness wiring diagram   Fri Jun 15, 2012 3:37 pm
I have all of these printed off from when I did my harness. Let me see what I can find. Which one do you need?
P.S. Skip the hooker and just buy me a soda when I get to meet you.
PostSubject: Re: s13 sr20det harness wiring diagram   Fri Jun 15, 2012 3:51 pm
Hand Jobs for everyone!
UNO!
DOS!
PostSubject: Re: s13 sr20det harness wiring diagram   Fri Jun 15, 2012 3:56 pm
That is all I could find take it or leave it.
PostSubject: Re: s13 sr20det harness wiring diagram   Fri Jun 15, 2012 5:31 pm
Ya i have those, i need the diagram to trace wires and if it shows colors thatas a bonus.
PostSubject: Re: s13 sr20det harness wiring diagram   Fri Jun 15, 2012 8:12 pm
Trace them to the connectors? They really aren't any repeat connectors and this show the colors for each item coming form the ECU. What more do you need. Use a continuity meter and and you should be all good that is what I did.
PostSubject: Re: s13 sr20det harness wiring diagram   Sat Jun 16, 2012 1:01 pm
Well i wish it was that easy to just trace, but i have 3 loose wires. 2 of which are unlabeled and the 3rd is labeled "C.O.P."
PostSubject: Re: s13 sr20det harness wiring diagram   Sat Jun 16, 2012 6:59 pm
Coil on plug? Multimeter with continuity is all you'd likely need as long as you had the connector views.
ttallin
PostSubject: Re: s13 sr20det harness wiring diagram   Sat Jun 16, 2012 7:59 pm
i should be able to get u the douches number who butttucked it if that might help??
PostSubject: Re: s13 sr20det harness wiring diagram   Sun Jun 17, 2012 9:47 pm
ya i thought that too, but the coil pack harness has all the wires in it and one side of that wire has been pinned. But its a the larger pin used in small plugs, not the pins used in the main blue plug. And continuity testing wont do me any good since i know where both ends are and neither are hooked up. Which is why im looking for a diagram with colors so i can trace it and the others.
ttalin idk if that would help. because i doubt they remember wtf they did anyways.
