 M24 Bolt or Pipe Plug
PostSubject: M24 Bolt or Pipe Plug   Fri Jul 13, 2012 1:56 pm
Anyone know where i can get my hands on a m24 pipe plug or a hex bolt ive been to home depot and lowes no one has it. i need one to plug the hole in my manifold where the egr tube was..
PostSubject: Re: M24 Bolt or Pipe Plug   Fri Jul 13, 2012 2:31 pm
I doubt you find that locally. [You must be registered and logged in to see this link.]
PostSubject: Re: M24 Bolt or Pipe Plug   Fri Jul 13, 2012 2:51 pm
If you still have the flare nut that held the tube in you should be a ble to stick a flat plug in the opening like a nickel and then tighten that bitch down with an impact and call it good. That is what I did for my SR when i swapped it and still had the OEM J-pipe.
PostSubject: Re: M24 Bolt or Pipe Plug   Fri Jul 13, 2012 2:53 pm
I agree with ^
PostSubject: Re: M24 Bolt or Pipe Plug   Fri Jul 13, 2012 3:24 pm
ace hardware *edit
m24 is pretty damn big, ace probably wont have it
PostSubject: Re: M24 Bolt or Pipe Plug   Mon Jul 16, 2012 7:17 am
This may be the route i go if i dont just buy the thing.
PostSubject: Re: M24 Bolt or Pipe Plug   Tue Jul 31, 2012 11:16 am
Figureed some shizz out
the bolt i need is a secret part from the nissan dealer runs like 9 bucks 14052-21R00
or a similar part for about 9 bucks at a gm dealer is 12549378 which is a drain plug
but the nissan part is specific for the blocking of the egr pipe and aiv pipe. thats why its secret lol
PostSubject: Re: M24 Bolt or Pipe Plug   Tue Jul 31, 2012 11:54 am
Secret's out!
PostSubject: Re: M24 Bolt or Pipe Plug   Tue Jul 31, 2012 3:43 pm
i just took my buddies headers to shop and had it welded up, drove around all day looking for a m24 size bolt and didnt have no luck
PostSubject: Re: M24 Bolt or Pipe Plug   Wed Aug 01, 2012 5:40 pm
I just chopped the pipe short and had the end welded shut.
