 Wheel size/ Tire size
PostSubject: Wheel size/ Tire size   Tue Aug 28, 2012 2:45 pm
looking to see if someone knows off he top of their head the max offset/ wheel width / tire width you can run on an s13 without pulling or rolling fenders i want something that fills out the sunken look with a little bit of a lip and that is got some nice wider tire. what can you fit in the front and rear i might fit ill probably run 17's or 18's not sure.
PostSubject: Re: Wheel size/ Tire size   Tue Aug 28, 2012 3:20 pm
This has been covered on zilvia and the 240sx.com sites.
PostSubject: Re: Wheel size/ Tire size   Tue Aug 28, 2012 5:21 pm
17x9+40 you could run a 265/275 in the rear without making to much fender enhancements. a 17x9+35 with a 255 wouldn't be a bad idea either.
This is apretty awesome thread.
Thats my buddy Ethans car with a 17x8+35 all around with 235/40/17 on all 4 corners.
PostSubject: Re: Wheel size/ Tire size   Tue Aug 28, 2012 7:38 pm
this is true but i dont frequent those sites searching sucks posters suck lots of bs and i figured why not get all the info right away instead of looking thru peoples bs. and have all our bs on one site.
PostSubject: Re: Wheel size/ Tire size   Tue Aug 28, 2012 7:42 pm
that looks perfect im thinking about that size now.. somewhere i read a +25 offset works? but im liking that setup.
im still tryin to find those exact skirts. anyone kno a place to look for em? i was looking for the canadain car lip kit.. still lookin.
PostSubject: Re: Wheel size/ Tire size   Tue Aug 28, 2012 7:43 pm
I don't frequent those sites either, but just like life, you have to wade through the BS to find something worthwhile. My comment wasn't meant to be dickish.
I believe Flicks link comes from zilvia, which he got from a simple search...
PostSubject: Re: Wheel size/ Tire size   Tue Aug 28, 2012 7:53 pm
Those are Chaser Aero replica chuki Skirts.
+25 would push those wheels out 10mm OUT. so yes those would fit.
PostSubject: Re: Wheel size/ Tire size   Tue Aug 28, 2012 8:03 pm
i know it wasnt being dickish im not being one either. just saying i have tons of free time at work.. i sit at a computer so i do my searches.. i wanted a simple awnser from someone who knew for sure. ive seen that thread theres just too much sometimes to make sense of. you have to take a crapshoot to figure what is exactly true and then i wanna see pics of this as flick did. he awnsered and showed me in a pic.. something i know i would have got here if i asked. and it worked out perfect. now i know and see.. now just to get my hands on some te37s and or some xd9's
PostSubject: Re: Wheel size/ Tire size   Tue Aug 28, 2012 9:21 pm
im gonna find me some of those lol
and the 10 mm out wouldnt hit fenders or anything? i want it as close to flush as possible even if i drop it on coils. and if i got 8.5's with the 35 offset id still be good? i want it wide looking from the rear and not all lobo looking aha.
is his car lowered and if so on what?
PostSubject: Re: Wheel size/ Tire size   Tue Aug 28, 2012 9:26 pm
I saw this on another site. does this sound right?
Quote :
I have run a 17x7.5 +35 with a 215/45/17 in the front with Megan racing coilovers and it just BARELY cleared. I'm now running a 17x7.5 +32 and its a better clearance for sure, same size tires.
In the rear I'm running a 17x9 +20 with a 235/40/17 on stock body (no rolling, no pulling) and its pretty close, but no rubbing. I'm pretty low on the Megans, no visible fender gap, but I'm also cambered in a bit (however much it cambered when I installed the coilovers)
PostSubject: Re: Wheel size/ Tire size   Tue Aug 28, 2012 9:31 pm
His car is on Megan street coilvers, You should still be fine depending on how big of a tire and ride height. Why do you not want to roll the fenders at all?
PostSubject: Re: Wheel size/ Tire size   Wed Aug 29, 2012 8:04 am
because i really dont wanna thats all. lol. i wanna fit what i can without the extra work and the risk of fucking shit up.
PostSubject: Re: Wheel size/ Tire size   Wed Aug 29, 2012 10:34 am
Makes sense, if you take it to a reliable and experienced fender place just rolling the fenders won't be an issue.
PostSubject: Re: Wheel size/ Tire size   Thu Aug 30, 2012 8:01 am
so what would you reccomemend as an "experienced" fender place and what am i looking at cost wise?
and one more question if i roll the fronts do i lose out on the plastic wheel wells i assume? how do you circumvent this. i like the protection of them...
PostSubject: Re: Wheel size/ Tire size   Thu Aug 30, 2012 12:28 pm
Vinny at Destruction Warehouse.
PostSubject: Re: Wheel size/ Tire size   Thu Aug 30, 2012 3:13 pm
As someone else said Vinny does a good job. But i've seen some less then great roll jobs from him. I would look up Sergeys house of Wheels out of North Chicago he does a GREAT job, Yes in theory you will loose the inner fenders, but with some time and looking at them you could figure out a way to mount them.
PostSubject: Re: Wheel size/ Tire size   Thu Aug 30, 2012 4:24 pm
Buy an extra set and cut and rivet them together making an EXTRA wide fender liner. Although if you are lowering your car you may run into issues rubbing them with your tires over bumps.
PostSubject: Re: Wheel size/ Tire size   Sat Sep 01, 2012 9:04 pm
and as for the fender rolling how much does this usually cost? ballpark figure
and who blew my rep down?
PostSubject: Re: Wheel size/ Tire size   Tue Sep 04, 2012 10:21 am
i think rolling is between $20-$40 per corner. usually $25.
PostSubject: Re: Wheel size/ Tire size   Wed Sep 05, 2012 8:58 pm
well then whats stopping me lol
