 Project Kouki Crazy
Koukicrazy
PostSubject: Project Kouki Crazy   Thu Oct 18, 2012 6:16 pm
So I just moved to Milwaukee. I stumbled upon this forum while searching Zilvia.net. I have been crazy about cars, and S13's in particular for the past 12 years. I currently have a 92 240sx SE, fully loaded with leather and a blacktop SR20DET. It has been an on going project for a long time now. It's not my daily driver, and I rarely have time to drive it, but sure have fun when I do.
Here are some pics of the project so far:
Koukicrazy
PostSubject: Re: Project Kouki Crazy   Thu Oct 18, 2012 7:02 pm
I then broke down the engine for cleaning and new gaskets. Installed a Megan Racing Turbo Manifold, Circuit Sports Stainless Braided Turbo Lines, New OEM oil pan & Strainer (old one was cracked), New rear main seal, Nismo thermostat, & S14 water neck outlet to make life easier.
PostSubject: Re: Project Kouki Crazy   Fri Oct 19, 2012 9:34 am
looks like you did alot of work! it looks good. how does it run?
PostSubject: Re: Project Kouki Crazy   Fri Oct 19, 2012 11:32 am
That car looks quite clean. SR Swap finished im assuming?
PostSubject: Re: Project Kouki Crazy   Fri Oct 19, 2012 1:28 pm
Looking good.
Koukicrazy
PostSubject: Re: Project Kouki Crazy   Fri Oct 19, 2012 3:16 pm
Thanks guys, and gal. Yeah, swap is finished and runs great! The current thing I am working on is the body. I have all the Kouki Body pieces, just waiting until next spring to install and paint. Haven't decided on exact color, but thinking some shade of blue.
More pics!
This is after I added the ACT HDSS Clutch, ACT Prolite Flywheel, Megan Racing Motor & Transmounts.
PostSubject: Re: Project Kouki Crazy   Sat Oct 20, 2012 7:37 pm
is that the 6 puck clutch? If so then i was running same setup. SOOOOO much holding power. And its a super lite flywheel adding more response. Get anything bigger than the stock t25 and your going to have a blast. Definitely will liven the car up a bunch.
Koukicrazy
PostSubject: Re: Project Kouki Crazy   Sat Oct 20, 2012 9:05 pm
It's actually the NS1-HDSS full face sprung disk. Still holds up to 372 ft/lbs though. But yeah, the 10.5lb ProLite Flywheel is boss. Love it.
Koukicrazy
PostSubject: Re: Project Kouki Crazy   Sat Oct 20, 2012 9:20 pm
I then installed my Greddy LS Spec Front Mount Intercooler, Koyo N Flow Radiator, Circuit Sports Rad Hoses, & Blitz RC.
P.S. My old camera was practically worthless.
Koukicrazy
PostSubject: Re: Project Kouki Crazy   Sat Oct 20, 2012 9:34 pm
Put everything back together and added some other goodies!
Apexi Dual Funnel Power Intake
Greddy Type RS BOV/Hotpipe Kit
NGK Iridium Spark Plugs
Top Fuel Oil Catch Can
PostSubject: Re: Project Kouki Crazy   Sat Oct 20, 2012 9:59 pm
no shroud for the the clutch fan? if so you might as well just take it off.
PostSubject: Re: Project Kouki Crazy   Sun Oct 21, 2012 12:35 am
LOL, 100% true.
First thing I saw too.
NEED a shroud. Ducting is what cools your engine, otherwise air takes the path of least resistance, which is not through your radiator, its around it.
Really nice car and build, please dont skimp here when you did so well everywhere else.
Koukicrazy
PostSubject: Re: Project Kouki Crazy   Sun Oct 21, 2012 12:52 am
I fully understand the function of the shroud. I don't have one or I would have installed it. But I have been driving it that way for years and have had ZERO issues with the temp since first start up. So it is not really a concern of mine.
Koukicrazy
PostSubject: Re: Project Kouki Crazy   Sun Oct 21, 2012 1:29 am
From there I picked up an Autometer Cobalt Series Boost Gauge, and single gauge pod. I'm not really a fan of the tri gauges on the pillar that most people choose. I upgraded the DIS Coils to Spitfire's Super Direct Ignition System, which really did make a noticeable difference as far as smoothing out the performance of the engine throughout the entire RPM range. After that I decided it was time for a new exhaust. I really liked the Apexi N1 Duals that my buddy had on his RB25 and was practically set on ordering one, until Enjuku got the ISIS Dual N1. I picked one up right away and could not have been more happy with it. Very quiet (which was my main concern), half the cost as Apexi N1 Duals, & I certainly could tell it assisted in making the engine much more efficient. Very Happy
Koukicrazy
PostSubject: Re: Project Kouki Crazy   Sun Oct 21, 2012 1:34 am
PostSubject: Re: Project Kouki Crazy   Sun Oct 21, 2012 3:12 am
how much did the splitfires run you? i've been looking into getting some but keep buying dumb shit like wheels.
but back to the shroud, lol. im sure you will notice a decrease in temps once you get one...post a wtb ad on zilvia....i got mine for like $35 shipped.....owning a black car im sure it will def help. lol
rbpowerd
PostSubject: Re: Project Kouki Crazy   Sun Oct 21, 2012 10:39 pm
i got a stock shroud in my shed ill sell for $30 ton of other shit too just message me if your intrested
PostSubject: Re: Project Kouki Crazy   Mon Oct 22, 2012 3:28 am
by stock i am assuming you mean a KA one which is different.
PostSubject: Re: Project Kouki Crazy   Wed Oct 24, 2012 9:35 am
i have those coils too. after fighting with stock ones that kept going bad, i just spent the money on them and have enjoyed not having misfires for the last 3 years now.
PostSubject: Re: Project Kouki Crazy   Wed Oct 24, 2012 11:38 pm
im debating on getting them or that yashio factory improved coilpack harness....which im sure i could replicate for way less....but im not a japanese tuning company so it wont be as cool.
anyway, what did you ngas pay for the splitfires?
Project Kouki Crazy
