 Drift car.
thatguywiththemohawk
PostSubject: Drift car.    Fri Jan 25, 2013 4:36 pm
My plan is drift car on a budget.
Plan is S13 probably hatch.
Getting ideas for a tubed front end.
Welded diff.
Stage 3-4 clutch.
Light flywheel n driveshaft.
Volk Te37's or probably replicas. Lol
And my biggest question and decision is what motor should I buy? I'm stuck between an RB, SR20DET, and KA-T. Want 300-400 hp stock internals.
PostSubject: Re: Drift car.    Fri Jan 25, 2013 6:02 pm
Do a single cam and I have a turbo kit with bigger injectors you can get like ~350hp
PostSubject: Re: Drift car.    Fri Jan 25, 2013 11:05 pm
i was thinking that, but the dohc have a bigger torque curve.
ttallin
PostSubject: Re: Drift car.    Mon Jan 28, 2013 10:32 am
sohc = torque
PostSubject: Re: Drift car.    Mon Jan 28, 2013 12:37 pm
sohc is waaaaaay better than the dohc. Only thing it doesnt have is a big aftermarket behind it like the dohc. sohc will take a lot more abuse.
And your budget is blown by tubing the front and buying te's or even reps.
Stock body, se wheels, a nice seat, sohc, and spend the rest on suspension.
Lets face it. Your new to it so dont build a racecar rite off the bat. Learn in something crusty so you dont feel soo bad when you wreck it the first day out. Also if the 160hp sohc (or w/e it has) isnt good enough. Find a 350 chevy and youll be in your budget still.
PostSubject: Re: Drift car.    Tue Jan 29, 2013 12:53 pm
Welded diff.
Stage 3-4 clutch.
Alot of that isn't really "needed" A diff, some Suspension and a decent seat and you would be good. A clutch upgrade is a good choice, You can fit some good sized wheels without needing to tube the front fenders.
and for 300-400hp on stock internals. you are either gonna need a GOOD tune on a KA or SR and still be on somewhat borrowed time, or do a Inline 6 or a V8. Then again 305whp and 405hp is a BIG difference.
PostSubject: Re: Drift car.    Tue Jan 29, 2013 3:14 pm
Alright new plans then, a 240sx, gut it, all new suspension, weld the diff. New clutch n fly.
And I feel like a I6 or V8 would be expensive. I was originally thinking 1jz but I was talked out of it cause the price.
PostSubject: Re: Drift car.    Tue Jan 29, 2013 3:55 pm
JZ stuff gets expensive yes. But so does attempting to build a 400hp SR/KA
PostSubject: Re: Drift car.    Tue Jan 29, 2013 4:59 pm
Maybe, and I mean maybe at first, but at the 300-400 hp you want to make, you're money ahead and more reliable.
PostSubject: Re: Drift car.    Tue Jan 29, 2013 8:45 pm
Buy my single cam and 5 speed trans.
And my full turbo kit. And your set
PostSubject: Re: Drift car.    Tue Jan 29, 2013 10:41 pm
RB20 or 1jz?
PostSubject: Re: Drift car.    Tue Jan 29, 2013 10:42 pm
What's done to it? Price?
PostSubject: Re: Drift car.    Tue Jan 29, 2013 10:43 pm
Touché.
PostSubject: Re: Drift car.    Wed Jan 30, 2013 6:18 am
dont bother attempting a 400hp ka. After 300 the reliability is gone. Sr is very do-able but by the time your done with it. Youll have spent what it costs to go 1/2j. RB's are decent stock but heavy and not as reliable as the 1/2j. Youll find that the 1/2j are much more forgiving. But chevy 350 is stupid cheap because there are soo many of the damn things and everyone is going LS. Thats cheaper than an LS or 1/2j and youll make 400hp reliably. Only down side is the cast iron block is heavy as fuck. so dont expect the car to handle like it did when you had a ka in it.
But serioulsy, dont bother trying to make power until you understand what your doing behind the wheel. I guarantee youll wreck the car. So dont spend a boat load of money on a crazy power plant thats way more than your abilities can handle. 200hp is plenty to get your dick wet behind the wheel just starting out.
PostSubject: Re: Drift car.    Wed Jan 30, 2013 10:03 am
The motor itself is stock for internals
But the turbo set up is a full cxracing kit
Check it online
With bigger injectors (which I also have)
And a maf and tune.
You can easy make 300-350hp
Private message me for more info and price and such
The whole turbo setup is brand new never ran or used
Miles on the motor and trans 101xxx.
PostSubject: Re: Drift car.    Wed Jan 30, 2013 3:05 pm
Sounds fucking amazing lol and yeah I plan on keeping it stock till I got that under control then boosting it on like 7lbs. Then finding a swap.
PostSubject: Re: Drift car.    Wed Jan 30, 2013 3:06 pm
Check it online
And a maf and tune.
Yeah, no offense but fuck that. Lol I wanna build me a car not buy someone else's build.
PostSubject: Re: Drift car.    Wed Jan 30, 2013 3:09 pm
I was told a 1jz swap would be 7-9k.... Please tell me this kid is a noob.
PostSubject: Re: Drift car.    Wed Jan 30, 2013 3:11 pm
What are you talking about?
Its not someone else's build.
Its a motor and trans together
And a turbo kit brand new. Only thing on the motor is the manifold
Everything else is in the box still
PostSubject: Re: Drift car.    Wed Jan 30, 2013 4:31 pm
Ok. Right now I don't want it.
PostSubject: Re: Drift car.    Wed Jan 30, 2013 4:33 pm
an SR swap done well is easily 5-7K, so yeah I am sure a 1J is easily 7k plus because it takes more custom parts to install it.
Good Luck!
PJs swap sounds like a great setup. 2cents
PostSubject: Re: Drift car.    Wed Jan 30, 2013 4:49 pm
yeah traphikcod4's setup for the price is a good setup for getting your feet wet with a turbo car on a budget.
a JZ Swap for $7k Is a pretty decent price, Thats going to be a fairly stock JZ setup as the wiring/mounts/parts/etc get pretty expensive not to mention the $2000-$4000 for a motor/trans.
PostSubject: Re: Drift car.    Wed Jan 30, 2013 5:21 pm
This reminds me of something that started like 800hp Sr build or something like that
PostSubject: Re: Drift car.    Wed Jan 30, 2013 5:35 pm
I was thinking the same thing...
PostSubject: Re: Drift car.    Wed Jan 30, 2013 5:46 pm
yup young naive. doesn't know what he's doing but his money. he can learn the hard way.
Drift car.
