 VLSD check
PostSubject: VLSD check   Tue Feb 12, 2013 7:40 pm
Dear 240 friends,
I looked at what was supposed to be a Vlsd tonight. When I went to grab the output flanges they seemed as though they were fixed or welded together. My understanding of a vlsd is that the axles don't. Lockup until there is a difference in wheel speed. And shouldn't you be able to spin them in opposite directions a little? With some resistance I would assume? I walked away from it for now. Thanks for your help!
PostSubject: Re: VLSD check   Tue Feb 12, 2013 7:44 pm
You would be correct, sounds like a dorifto ritard diff.
PostSubject: Re: VLSD check   Tue Feb 12, 2013 8:20 pm
Thanks Jim! <3
PostSubject: Re: VLSD check   Tue Feb 12, 2013 8:34 pm
just have the seller pull the cover. Then see if its a welded or not. Dont ever buy a diff because of what the output shafts do. And Jim is correct although if it was re-shimmed incorrectly (like a lot of dip shits are doing) it will not move independently.
Hell it could be an lsd and the seller doesnt know.
PostSubject: Re: VLSD check   Tue Feb 12, 2013 8:51 pm
I will probably do that. The guy was wearing mechanics clothes from a Toyota dealership so you would assume he would have some idea what he was looking at and how to work on one. The diff is supposedly from a 180sx. 5 bolt output flanges and no ABS sensor. He claimed that it worked great in his car.
PostSubject: Re: VLSD check   Tue Feb 12, 2013 8:57 pm
Also if the fluids were drained out could that cause this issue?
PostSubject: Re: VLSD check   Tue Feb 12, 2013 10:37 pm
Great for what, sideways?
And it is possible that no fluid could cause a lockup type condition.
nick z
PostSubject: Re: VLSD check   Wed Feb 13, 2013 8:31 am
You will not be able to grab flanges and spin opposite of eachother while diff is on bench. But in the car yes it will slip on VLSD by grabbing the wheels, its a leverage thing. I have stock q45 vlsd in basement and cant spin them and i know its stock and not welded. I bet its not welded but bring a makita and a 12mm and see first.
PostSubject: Re: VLSD check   Wed Feb 13, 2013 8:50 am
both of mine spin the same way. if you spin one side. but you should be able to force them the opposite ways.
nick z
PostSubject: Re: VLSD check   Wed Feb 13, 2013 9:27 am
Yea you can force them but not easily while its out of the car.
PostSubject: Re: VLSD check   Wed Feb 13, 2013 4:52 pm
Yeah I tried as did the guy selling it. It wouldn't budge. I will see if he will open it up for me. Otherwise I will just keep my eyes open for another one.
PostSubject: Re: VLSD check   Thu Feb 14, 2013 9:39 am
So if this gentleman cooperates and opens the case to verify it is not a welded diff do any of you see any reason not to buy it given the previous info I have given you? Thanks again!
PostSubject: Re: VLSD check   Thu Feb 14, 2013 9:40 am
No
PostSubject: Re: VLSD check   Thu Feb 14, 2013 9:47 am
No don't buy it, or no no worries get it?
PostSubject: Re: VLSD check   Thu Feb 14, 2013 9:49 am
No reason not to buy.
nick z
PostSubject: Re: VLSD check   Thu Feb 14, 2013 3:55 pm
haha, next one will feel exactly the same ..
PostSubject: Re: VLSD check   Sun Feb 17, 2013 11:25 am
Thanks for the help guys! My car will be doing 2 wheel skids this summer!
VLSD check
