 good header for low cheap
redonkulous240
PostSubject: good header for low cheap   Wed Feb 20, 2013 1:30 am
HI I got a full 3" apexi n1 exhuast. I need a nice header but don't have much to spend right now. My problem is I have no other exhaust for the car and need one on asap. What would be a good header for cheap?
PostSubject: Re: good header for low cheap   Wed Feb 20, 2013 10:34 am
pacesetter? No real reason for a header on a KA don't seem to pick up much.
redonkulous240
PostSubject: Re: good header for low cheap   Wed Feb 20, 2013 3:42 pm
would the stock header/ manifold bolt up to a 3" down pipe?
PostSubject: Re: good header for low cheap   Wed Feb 20, 2013 7:55 pm
The de mani is almost like a 4-2-1 header to start out. Pacesetter are nice.
redonkulous240
PostSubject: Re: good header for low cheap   Sat Feb 23, 2013 3:21 pm
what header would hook up to this down pipe?
PostSubject: Re: good header for low cheap   Thu Feb 28, 2013 8:31 am
I take it that's a dp for an sr20det. I believe the s14 ka header will allow you to use that dp.
PostSubject: Re: good header for low cheap   Thu Feb 28, 2013 12:27 pm
No that looks like a down pipe for a turbo setup. Like i state before the de exhaust is set up like a 4-2-1 header. The mani has two outlets
PostSubject: Re: good header for low cheap   Thu Feb 28, 2013 12:42 pm
The sr20det dp has a three bolt flange like that. After researching, I found the s14 ka header will bolt up to an sr dp. I'm guessing ka mani from s13 and s14 are different but you can fit a s14 header on s13.
PostSubject: Re: good header for low cheap   Thu Feb 28, 2013 1:59 pm
Here is the image of the stock ka de.
I had the the issue of trying to figure out what to put on my ka. I ended up just buying a pacesetter and calling it a day
PostSubject: Re: good header for low cheap   Thu Feb 28, 2013 2:59 pm
That is s13, the s14 is different and three bolt flanged. Also this mod is done many times. Seriously, google it.
PostSubject: Re: good header for low cheap   Fri Mar 01, 2013 6:05 am
These 2 will work if you unbolt the down pipe from your cat or test pipe(w/e your using).
Or i believe this one will bolt up to an sr down pipe that doenst have the turbo elbow incorporated in it. (s14 version)
The flange on your exhaust is a standard 3" 3 bolt flange.
PostSubject: Re: good header for low cheap   Fri Mar 01, 2013 8:46 am
I hope you have something to quiet it down, a straight thru exhaust is awefully annoying on a NA. I dont want you to *facepalm yourself the first time a LEO writes you a citation.
PostSubject: Re: good header for low cheap   Fri Mar 01, 2013 12:04 pm
