 lsx swap help thread
PostSubject: lsx swap help thread   Thu Feb 21, 2013 3:49 pm
Figure I'd just move our convo here Jim. So we don't just blow up my build thread haha
So yea I got all wiring for the motor and trans and ecu
PostSubject: Re: lsx swap help thread   Thu Feb 28, 2013 4:18 pm
Hey Jim
I was wondering what you all did for a set up to bleed the clutch
And what hoses for the radiator are you using.
PostSubject: Re: lsx swap help thread   Thu Feb 28, 2013 4:36 pm
I found a thread on silviav8forums that listed the parts needed for the remote bleeder, and bought all the stuff from speedway automotive, I believe. The clutch master was a different story. I bought a kit from Hinson (I think), and had to buy a different wilwood 7/8" master from somewhere else, because I had nothing but problems with the one from Hinson. Remember, you will need the mounting adapter as well!
The radiator hoses I bought from Napa when Eron still worked there. I just went in the back room and found 2 hoses that would work with little modification. The lower is part # 9006, and the upper is missing the tag... so I don't know. I also found a U-shaped hase for the heater hose outlets there.
PostSubject: Re: lsx swap help thread   Thu Feb 28, 2013 5:21 pm
I'm getting the clutch master from fueled racing. I believe its the wilwood one. I'll double check if it has the adapter
What do you think about putting a hole in the trans tunnel for easy access and put a rubber gromet in the hole?
PostSubject: Re: lsx swap help thread   Thu Feb 28, 2013 5:25 pm
That's fine I guess, as long as you don't mind brake fluid in your interior. It will happen. I just ran mine right back up the feed line and it ends at the master.
PostSubject: Re: lsx swap help thread   Thu Feb 28, 2013 5:32 pm
I guess this comes with everything
Bleeder line and adapter and cmc and all
PostSubject: Re: lsx swap help thread   Thu Feb 28, 2013 5:38 pm
Looks good.
PostSubject: Re: lsx swap help thread   Thu Jun 27, 2013 6:57 am
Did the clutch master adapter I gave you work?
PostSubject: Re: lsx swap help thread   Thu Jun 27, 2013 10:36 am
Yes it was a tight squeeze with the holes but it did work.
I also don't think that part of the firewall was jacked up from the kid drilling to make it 5speed
Driveshaft is on
Brakes are getting put back on today
Trying to figure out how I'm going to run my fans
