 S13 Rear Hub Removal
ujsp
PostSubject: S13 Rear Hub Removal   Tue Jun 25, 2013 9:08 pm
Who's got some tips for removing the rear hub assembly from the knuckle on an S13?  I'm in the middle of my 5 lug swap, and these things just wont budge.
I have removed the axle nut, and freed the axle splines from the hub splines (axle splines move freely).
I have removed all 4 bolts holding the hub to the knuckle.
I have tried hitting the thing every which way with a deadblow, and a mini-sledge.
I have tried threading the bolts back into the hub a bit, and hitting them with a deadblow/mini-sledge.  I cant get a great angle on them with the axle in the way.
I have tried bolting the wheel back on and mule-kicking the crap out of it.  This only served to create severe play in the bearing itself.  The mating surface of the hub is still rock solid stuck onto the knuckle.
I'm thinking I may just pull the entire knuckle from the car and either:
A) Have the old hub pressed off at a machine shop
B) Buy someone elses knuckles with the hubs already removed (If anyone has any, let me know).
Anyway, I know this has been covered to death, I just thought I would give everyone the chance to share how they were able to separate these things.
PostSubject: Re: S13 Rear Hub Removal   Tue Jun 25, 2013 9:11 pm
Some sort of a penetrant (pb blaster, etc) a slide hammer, and/ or an air hammer.
ujsp
PostSubject: Re: S13 Rear Hub Removal   Tue Jun 25, 2013 9:13 pm
The thing has been soaking in PB for the past day or two, I love that stuff.
I have not tried a slide hammer though.  I'll see if I can borrow one from a friend.
PostSubject: Re: S13 Rear Hub Removal   Tue Jun 25, 2013 9:14 pm
Get a BIG slide hammer, not the pussy small one... not enough momentum.
ujsp
PostSubject: Re: S13 Rear Hub Removal   Tue Jun 25, 2013 9:29 pm
Are you talking about using an attachment that bolts onto the lug studs, or one that goes through the middle of the hub and pulls on the back side?  Because the one that pulls on the lug studs will probably just separate the bearing, and I'll still be left with the inner part of the hub seized onto the knuckle, correct?
PostSubject: Re: S13 Rear Hub Removal   Tue Jun 25, 2013 9:34 pm
With that setup, yes.  You could always pull the axle off the diff and sneak it out the back side and either try to get a slide hammer thru it if the hub separates.  Or, that could be where an air hammer could work well.
PostSubject: Re: S13 Rear Hub Removal   Wed Jun 26, 2013 10:46 am
Slide hammer should do the trick. Two or three tugs on one and the hub came off. I believe most auto part stores rent them.
PostSubject: Re: S13 Rear Hub Removal   Thu Jun 27, 2013 8:29 am
Heres the tool i used after i pulled the hub on my Altima. (hub came out of bearing..) This will pull the bearing out just make sure you grease the tool up a lot. You can use this also to press bearings in.. and to pull the hub i just used a regular old hub puller like this one
otherwise like i said best bet get them things off and have em pressed out at any old shop.
let me know what worked for ya.
PostSubject: Re: S13 Rear Hub Removal   Thu Jun 27, 2013 12:16 pm
grab a torch, heat up the knuckle ONLY. Put the bolts back in the hub and swing for the fences. Its much easier with the knuckle off.
Ive got a set of knuckles for sale if your interested
