 matt's s13 sr20det gt2871 build
Go to page : 1, 2, 3, 4, 5, 6, 7  Next
PostSubject: matt's s13 sr20det gt2871 build   Sun Jan 16, 2011 5:11 pm
Just ordered all the stuff for my turbo upgrade build.
Current setup:
s13 coupe, blacktop sr20det with stock t25, FMIC, Hks cam, KAAZ lsd, greddy BOV, Header, Megan 3" downpipe,greddy manual boost control, stock exterior and interior, apexi coilovers, sway bar,front/rear strut braces.
Parts purchased for upgrade:
Gt2871 .64
ISIS rocker arm stoppers
ISIS stainless turbo lines
ISIS lightweight pulley set
walbro fuel pump
fiveO 750cc inj
z32 MAF
Apexi head gasket
ARP head studs
300zx fuel filter
Megan fuel pressure regulator
enthalpy tune
Spec stage 3 clutch
short shifter kit
Engine torque damper
circuit sports aluminum overflow bottle
Aluminum catch can
Kaaz gear oil
new oem crank pulley
Debating on which, if any, body kit and rims to get
Everything should be here this week, I'M SO EXCITED!! its like christmas all over again.
Im gonna pull the engine to clean it up and paint my engine bay, i will take pictures of the whole process hopefully get it done in one day, maybe two.
PostSubject: Re: matt's s13 sr20det gt2871 build   Sun Jan 16, 2011 5:15 pm
oh yeah funny thing, this was my total from enjuku racing no lie!! 2871 thats messed up
PostSubject: Re: matt's s13 sr20det gt2871 build   Sun Jan 16, 2011 6:14 pm
Good luck with everything! take lots of picks and keep us posted. I am curious about how your Enthalapy tune turns out.
PostSubject: Re: matt's s13 sr20det gt2871 build   Sun Jan 16, 2011 6:27 pm
i hope good, i called martin before i bought the parts to give me some pointers, i figure i should build it the way the tuner recommends not to my unknowlegable standards.
PostSubject: Re: matt's s13 sr20det gt2871 build   Sun Jan 16, 2011 7:01 pm
This is going to be an interesting build keep us posted
PostSubject: Re: matt's s13 sr20det gt2871 build   Sun Jan 16, 2011 9:19 pm
this will be a good setup, looking forward to seeing how it turns out.
PostSubject: Re: matt's s13 sr20det gt2871 build   Mon Jan 17, 2011 9:38 am
damn!!!!! can't wait to see it all done!
PostSubject: Re: matt's s13 sr20det gt2871 build   Mon Jan 17, 2011 7:26 pm
Won't be gettin it done while there's good snow to ride on. Gotta go snowmobiling while theres snow!!
PostSubject: Re: matt's s13 sr20det gt2871 build   Wed Jan 19, 2011 10:22 pm
don't remind me.
how are the trails up by you? my brothers are talking about going up north in the next week or two.
PostSubject: Re: matt's s13 sr20det gt2871 build   Wed Jan 19, 2011 11:37 pm
i just got back from a 80 mile ride from oshkosh to appleton and back, some of the fields are not the greatest but overall there pretty good, ill be heading up north fri night till we find real good snow, maybe upper michigan,
PostSubject: Re: matt's s13 sr20det gt2871 build   Thu Jan 20, 2011 12:48 am
have fun stay safe.
PostSubject: Re: matt's s13 sr20det gt2871 build   Mon Jan 24, 2011 8:06 pm
got home from a 280 mile snowmobile ride and i had 10 packages waiting for me!! I must be living the life!
ino20
PostSubject: Re: matt's s13 sr20det gt2871 build   Tue Jan 25, 2011 7:50 am
yes you are sir Shocked
http://www.no-drift.tumblr.com
PostSubject: Re: matt's s13 sr20det gt2871 build   Tue Jan 25, 2011 3:49 pm
All of the parts you have look great! Just like X-mas all over again. I will tell you from personal experience that the Short shifter kit that you bought may let you down. I had(still have in box) that same one on my car for about 2 months. It would loosen up and I had to retighten the bolts that hold the clamp\bracket together. One time it actually slipped off the trans while I was driving, talk about a nerve racking moment when your shifter suddenly gets sloppy as hell. I would consider spending the extra $$ on a B&M. I did and it is worth it. I actually posted somthing about this in the Favorite Mods thread. Best of Luck with the installs though, have fun!
PostSubject: Re: matt's s13 sr20det gt2871 build   Tue Jan 25, 2011 8:27 pm
thanks for the heads up, the reason i bought it was that some joker had to go and grind all the threads off of mine( and did a sh!tty job of it) so absolutly nothing fits on it. i figured it was a cheap way to be able to install a sshift knob. if anyone has a stock shifter i would buy it. I deal with crappy accessories and modifying them to actually function on a daily basis so if i need to i will.
PostSubject: Re: matt's s13 sr20det gt2871 build   Tue Jan 25, 2011 9:25 pm
with this setup what fuel pressure should i be running is 43.5 gonna be fine, i think im gonna be around 15-18psi of boost. is there a way to bench set the fpr to get it close to 43psi can i blow compressed air in and set it??
PostSubject: Re: matt's s13 sr20det gt2871 build   Thu Jan 27, 2011 9:02 am
The best way to make sure you are running the correct amount of fuel is to monitor it from a WideBand A/F meter. Then if you are lean you will need more fuel if you are rich less. If you are getting a rom tune by Enthalapy you should be able to tell him what your setup is and the ECU will/should be able to compensate for most of the the A/F issues, providing you have a good pump and injectors. I have read(not tested personally) that if you run a 255LPH fuel pump on a stock FPR that you will run a little bit higher fuel pressure than with the stock pump. The only way to check your pressure is with yet another guage. Also if you would like a stock shifter I have 2 of them one from a KA tranny and the other from a SR tranny. I believe that there is no difference between them. LMK if you are interested.
PostSubject: Re: matt's s13 sr20det gt2871 build   Sun Feb 06, 2011 10:51 am
How is the build going? Any updates/pics?
PostSubject: Re: matt's s13 sr20det gt2871 build   Sun Feb 06, 2011 12:21 pm
not really unfortunatly, ive been snowmobiling every other day. this is the importance order of my shed haha
PostSubject: Re: matt's s13 sr20det gt2871 build   Mon Feb 14, 2011 7:26 pm
GAY weather means no more snowmobiling around here. looks like ill be rippin and a tearin down the 240 next saturday.
PostSubject: Re: matt's s13 sr20det gt2871 build   Mon Feb 14, 2011 9:00 pm
Looking pretty sweet there.
PostSubject: Re: matt's s13 sr20det gt2871 build   Fri Feb 25, 2011 4:45 pm
any updates
PostSubject: Re: matt's s13 sr20det gt2871 build   Sun Feb 27, 2011 1:23 am
PostSubject: Re: matt's s13 sr20det gt2871 build   Sun Feb 27, 2011 12:45 pm
nice
PostSubject: Re: matt's s13 sr20det gt2871 build   Sun Feb 27, 2011 3:08 pm
Sweet. Sent you a friend request on Flickr.
Page 1 of 7Go to page : 1, 2, 3, 4, 5, 6, 7  Next
