 matt's s13 sr20det gt2871 build
Go to page : Previous  1, 2, 3, 4, 5, 6, 7  Next
PostSubject: Re: matt's s13 sr20det gt2871 build   Mon May 16, 2011 10:59 pm
i like this sign #
PostSubject: Re: matt's s13 sr20det gt2871 build   Mon May 16, 2011 11:06 pm
the small ones on my keyring. you think they woulda made the kangaroo face the same way as the arrow at least haha, Metzler does that with there bike tires, The elephant runs the same direction as rotation.
PostSubject: Re: matt's s13 sr20det gt2871 build   Mon May 16, 2011 11:08 pm
haha i have a small piston as my keychain too. and a lot of people are like wtf is that out off an i say, my hot wheels and they believe me lol
PostSubject: Re: matt's s13 sr20det gt2871 build   Mon May 16, 2011 11:52 pm
haha losers.
PostSubject: Re: matt's s13 sr20det gt2871 build   Tue May 17, 2011 7:06 am
hey i believed him... lmao jkjk
PostSubject: Re: matt's s13 sr20det gt2871 build   Fri May 27, 2011 6:45 pm
Finally Got my block back today!!
PostSubject: Re: matt's s13 sr20det gt2871 build   Fri May 27, 2011 9:59 pm
Good deal. Let's get that bitch together!
PostSubject: Re: matt's s13 sr20det gt2871 build   Sun May 29, 2011 9:41 am
Kenwould does monster trucks too...m
PostSubject: Re: matt's s13 sr20det gt2871 build   Tue May 31, 2011 7:24 pm
Whats the latest? on the build that is.. Sleep
PostSubject: Re: matt's s13 sr20det gt2871 build   Tue May 31, 2011 8:55 pm
Assembly starts tomorrow after work! Ill keep you posted!
PostSubject: Re: matt's s13 sr20det gt2871 build   Wed Jun 01, 2011 7:36 pm
awesome!!
PostSubject: Re: matt's s13 sr20det gt2871 build   Wed Jun 01, 2011 8:49 pm
PLEASE DO.
PostSubject: Re: matt's s13 sr20det gt2871 build   Wed Jun 01, 2011 10:29 pm
Mad ARGH i didnt really look at my block till today, couple GOOD SIZED scratches in the deck, Which for sure were NOT there before, and also lokks like he took an angle grinder with wire wheel to the deck for some reason beyond me. So i took it over to him and now hes gonna charge me $40 (half what he would usually charge) to deck it. for something that he did!!
side note: i put a nice hone job on the cylinders. other than that a waste of a night.
PostSubject: Re: matt's s13 sr20det gt2871 build   Thu Jun 02, 2011 6:03 pm
That really sucks. I aboslutely hate letting other people work on my car. There seems to be a lack of respect and appreciation by most when it isn't your own. I do understand that certain projects are unavoidable, hopefully the guy still does a good job anyway.
PostSubject: Re: matt's s13 sr20det gt2871 build   Thu Jun 02, 2011 10:32 pm
Where did you take it??
PostSubject: Re: matt's s13 sr20det gt2871 build   Sat Jun 04, 2011 4:13 pm
automotive specialists, AKA Weezy. in oshkosh
dont worry i got it back after being decked, Cleaned it all up AGAIN and in the process of plastigauging the crank a main stud pulled the threads out of the block, no big deal i thought id just heli coil, Tapped off the area around the hole so i wouldnt get shavings in any holes thaat i just cleaned, went to the bin grabbed a 10m coil, to small, grabbed a 12mm, it spun on stud, so i proceeded to drill tap and carefully collect and remove all metal shavings, go to screw stud in, SOB was all wobbly, TURNS OUT that nissan decided to make 11mm studs, WTF NO one uses 11mm shit, grab the handy McMaster car book to check for helicoils or time serts since they have everything known to man in there, NOT A SINGLE 11mm Insert???
so now im on the hunt for a 11x1.5 insert to fit in a hole tapped to 14mm.
(If there was a smilly guy bent over taking it in the rear buy a nissan symbol i would insert that here)
PostSubject: Re: matt's s13 sr20det gt2871 build   Sat Jun 04, 2011 8:00 pm
http://www.manta.com/c/mtmt1lr/universal-metrics-inc
PostSubject: Re: matt's s13 sr20det gt2871 build   Sun Jun 05, 2011 7:46 pm
These are the some of the marks in the deck
Taped off for drilling the hole
Sucking the shavings out
PostSubject: Re: matt's s13 sr20det gt2871 build   Sun Jun 05, 2011 7:51 pm
That one mark doesn't look good going from the cylinder to the water jacket if you plan on using a steel shim head gasket.
PostSubject: Re: matt's s13 sr20det gt2871 build   Mon Jun 06, 2011 10:48 am
Thats what happens when you slide a block across the ground.
That is that guys fault for sure (even though you resolved the issue).
Set the block deck side down cause its the only flat surface, scooted it across a bench or something. Sucks to hear man.
Hope you get it together without too much bother.
PostSubject: Re: matt's s13 sr20det gt2871 build   Tue Jun 07, 2011 5:40 pm
Fuuuuuuuuuuu!!!
PostSubject: Re: matt's s13 sr20det gt2871 build   Wed Jun 29, 2011 7:06 pm
FINALLY ordering a insert kit unfortunatly its $272 dollars. maybe this thing will get done before the snow fly's
PostSubject: Re: matt's s13 sr20det gt2871 build   Wed Jun 29, 2011 7:10 pm
I thought you forgot about us. Very Happy Don't give up!
PostSubject: Re: matt's s13 sr20det gt2871 build   Sun Jul 10, 2011 1:28 pm
Well i got the main stud hole repaired last night got the whole bottom end assembled. Attempted to torque the head and BOOOM 2 head studs pulled the threads out at 60 ft lbs and full torque is 85. Now I gotta find a way to fix those deep holes, unfortunatly i cant even use the kit i bought for the main stud repair. SH!T
Repaired hole
Bottom end together
preparing head install
Packing it up
PostSubject: Re: matt's s13 sr20det gt2871 build   Sun Jul 10, 2011 4:03 pm
Very Nice!!! Replace that Water Pump if you can.....SRs can be notorious for those....
No spray copper on the HG?
Page 4 of 7Go to page : Previous  1, 2, 3, 4, 5, 6, 7  Next
