 some minor problems but need help please
PostSubject: some minor problems but need help please   Sun Feb 20, 2011 12:02 pm
well guys i got a new 240sx but it has some minor issue that im not to worried about right now but would like it to get fixed...
passenger side door wont close tightly and seems the door is tilted side ways alittle because the window isnt pressed firmly against the car but the bottom is and seems to stick in more by the rocker then the driver side
all the locks on the car wont turn... ive had these problem before but not for all the locks at the same time so this is a must before the car goes out and around this spring "not worried about anyone breaking in right now because my two boys rex and couger will let me know when someone is around my house"
ill post anymore problems if i find any more and itd be great if anyone knew how to fix these without spending alot of money
feyd_w
PostSubject: Re: some minor problems but need help please   Sun Feb 20, 2011 3:35 pm
are the mounts for the door just bent?
PostSubject: Re: some minor problems but need help please   Sun Feb 20, 2011 4:31 pm
i would think so alittle because when i lift the door, i can feel it move up and down... dont really know why it wont close tight though
PostSubject: Re: some minor problems but need help please   Sun Feb 20, 2011 5:52 pm
Check your door hinges/mounts. Bushing could be worn out bad. Or someone might of been doing something with the door causing the hinges to bend.
PostSubject: Re: some minor problems but need help please   Sun Feb 20, 2011 8:22 pm
Sounds like you need hinge pin kits.
PostSubject: Re: some minor problems but need help please   Sun Feb 20, 2011 10:09 pm
thanks both of u guys... ill check the hinge pin out when the dam snow stops tomorrow... we got about a foot of snow today... dam snow
PostSubject: Re: some minor problems but need help please   Sun Feb 20, 2011 11:38 pm
Wow we got non except for rain.
PostSubject: Re: some minor problems but need help please   Mon Feb 21, 2011 11:21 am
lucky... i just spent the last hr shoveling snow because the dam blower wouldnt start... i think i might of fucked up my wrist too... kinda hurts... lol
PostSubject: Re: some minor problems but need help please   Mon Feb 21, 2011 4:40 pm
Is it possiblle that the key for the ignition is not the same as the one for the doors? That would be a good reason that none of them work. Was this deal legit with a clean title and everything? If the guy was in a rush and you have weird things like locks not working, I would be suspicious. Although, you have the car now. Good luck.
PostSubject: Re: some minor problems but need help please   Mon Feb 21, 2011 9:16 pm
lol yeah but i checked the vin... the key looks old and like its about to break so im gonna get a spare made and will see if i can get some to fit
