 does soemeone know the wheel size in this car?
PostSubject: does soemeone know the wheel size in this car?   Fri Feb 25, 2011 9:34 pm
http://27.media.tumblr.com/tumblr_l9jboxvY6p1qzg3k3o1_500.jpg
i want the same rear rims on that car and i did my research and i couldnt find anything so if anyone knows the rear rim size,offset that would be awesome
PostSubject: Re: does soemeone know the wheel size in this car?   Fri Feb 25, 2011 11:13 pm
Here's what I found on the car... wheels are Aero Race Wheels 15 x 10... offset??????
Engine:
05′ Ls2 swap
t56 6 speed
sikky mounts
sikkyheaders x pipe
sikky oil relocation
msd starter
pulstar plugs
msd wires
gm wiring harness drive-by-wire
Suspension:
isis rucas/toe rods/traction rods/ front tension rods
custom fender braces
megan coilovers
tein tie rods
stance subframe bushings
megan rear sway bar
sikky front sway bar
Interior:
Full custom cage
aeromotive 15 gal. fuel cell
custom steering shaft
quick release wheel
takata harnesses
auometer gauges
buddy club seats
window nets
custom plaid dash/door planels
wilwood clutch/brake pedals with master cylinders relocated behind the dash
custom hydraulic e-brake
Exterior:
silvia front end conversion
dmax 40 mm front/50 mm rear wide body fenders
shaved gas lid, door handles and fender vents
dmax smoked tail lights
oem silvia side skirts
instant gentleman front bumper
fiberglass roof, gm pearl white/ gm pewter paint
autocatch hood/truck latches
black aero 15×10 wheels
PostSubject: Re: does soemeone know the wheel size in this car?   Sat Feb 26, 2011 12:11 am
dude is on fucking top of shit.
that car would be about 100000000 times better with cooler wheels, I like those wheels just not on that car.
PostSubject: Re: does soemeone know the wheel size in this car?   Sat Feb 26, 2011 1:11 am
Thanks for the ingo guys, I know that car would look a lot cooler with better wheels but they are dirt cheap and they have some sweet offsets, but i just want to find offset on that car cause i have the same origin 50mm wide quarters and i like how the wheels sits nicely with the fender but i think im going with 16x10 but still devating on a +12 or -12 offset, or wat do u guys think
PostSubject: Re: does soemeone know the wheel size in this car?   Sun Feb 27, 2011 9:17 pm
+12 and -12 offset is about an inch difference... I did the calculations and here's what you'll have to do:
With the wheel off, measure the distance from your wheel hub (the surface of the brake rotor that touches the rim).
The 10 inch -12 offset wheel would come out a distance of about 5.5 inches from the hub.
The 10 inch +12 offset wheel would come out a distance of about 4.5 inches from the hub.
That's all the information. So you can find out how much space it's going to fill with the 50mm quarter panels on. Good luck, I hope that helps.
PostSubject: Re: does soemeone know the wheel size in this car?   Mon Feb 28, 2011 11:46 am
thanks for the info man im going to have to do that, i just dont know much of offset, camber, caster an all that crap Razz
PostSubject: Re: does soemeone know the wheel size in this car?   Tue Mar 01, 2011 12:29 am
You're welcome. I can teach you how to figure it out some time in person. I gotta draw it out and explain it while I'm drawing, Lol. So next meet, I hope to be there. =P
PostSubject: Re: does soemeone know the wheel size in this car?   Tue Mar 01, 2011 1:26 am
^ yeah man that would really help and yea im definatley going to be at the next meet
PostSubject: Re: does soemeone know the wheel size in this car?   Thu Mar 10, 2011 6:17 pm
THAT LOOKS LIKE NASCAR!!! cheers Must be the LS swap... Laughing
PostSubject: Re: does soemeone know the wheel size in this car?   Thu Mar 10, 2011 9:31 pm
Hehe, reminds me of Diamond Racing wheels. All business.
Wisconsin240sx :: General Chat-
