 NEED HELP ASAP!!!!
91coupe
PostSubject: NEED HELP ASAP!!!!   Wed Mar 16, 2011 7:38 pm
Ok here is the run down.
1993 KA24DET external wastegate making only 5psi!
Its running a Z32 MAF and 550cc injectors. I am using a APEXI SAFC2 to tune the motor and have some problems!
The car idles perfect and when i rev the motor up fast its fine! However, when i rev it up really slow it seems like a sputtering or missing!
I just changed the plugs thinking that could be the problem, but i think its getting to much fuel?
Running stock FPR, and stock fuel pump!
These are the setting i am using:
Lo map is -50% across the board
High map is -50% from 1000-2200rpm's, -45% at 2800rpm's and -35% 3400-7000rpm's
NE points are 1000,1600,2200,2800,3400,4000,4600,5200,5800,6400, 7000, and 7600rpms
Dec settings are 1.1,1.4, and 2.0
Throttle point is 10% and 33%
Any help would be greatly appreciated!
Thanks
Kyle
PostSubject: Re: NEED HELP ASAP!!!!   Wed Mar 16, 2011 7:51 pm
simple stuff,
plugs/wires/cap/rotor all decent? your timing alright? does it smell or smoke enough to look rich? do you have a wideband do see what the AFR's are at?
PostSubject: Re: NEED HELP ASAP!!!!   Wed Mar 16, 2011 9:37 pm
Plug gap is rather important too, after you check all of the above.
What color were the plugs? Tan? Black? White? That will tell you what exactly is going on inside the motor during combustion and help you lean one way or another on a rich/lean condition.
91coupe
PostSubject: Re: NEED HELP ASAP!!!!   Wed Mar 16, 2011 9:46 pm
simple stuff,
Has new plugs, new rotor and cap! Car is running rich however its just a cheap Prosport gauge!
Thats were i assume its too much fuel! I found some different settings for the SAFC im going to try but don't know if that will fix it!
These are settings i found online that might work! I plan to try tomorrow:
stock ecu/550cc injectors/walbro/z32maf/stock FPR
ETC Menu:
Sensor type: Hot-wire: 1in 6out: 2in ADDout
Car Select: 4 cyl thr -> (arrow pointing up)
Initialize (this is the menu you use to reset the safc)
Setting Menu:
Low Throttle:
1k -50%
2-8k -40%
Hi throttle
1-3k 0%
4k -24%
5k -30%
6-8k -31%
THR Point:
20% low 40% high
Dec. Air:
Thr 2.0%
Ne1 .7%
Ne2 2.0%
But when it revs up slow it starts sputtering hard from 2-4.5 with the current tune! If it does the same with these settings should i change injectors to like 370's?
91coupe
Plugs were BLACK!
PostSubject: Re: NEED HELP ASAP!!!!   Wed Mar 16, 2011 10:41 pm
Had the same problem before on an MK3. Turned out to be a boost leak. MAFS was reading all that air, injectors spittin extra fuel for it. All the boost leaking out caused it to run rich. Also would explain the 5psi problem you're getting? and black plugs. Good luck.
PostSubject: Re: NEED HELP ASAP!!!!   Wed Mar 16, 2011 10:46 pm
good thought.
91coupe
PostSubject: Re: NEED HELP ASAP!!!!   Wed Mar 16, 2011 11:11 pm
What would you suggest doing? Boost leak test? Check all the lines? Could it be a bad wastegate?
PostSubject: Re: NEED HELP ASAP!!!!   Thu Mar 17, 2011 12:01 am
I'm not sure how to perform a boost leak test in this case, but if you can. Go for it. If the test shows you're leaking, then checking the lines and fittings would be a good way to start looking.
PostSubject: Re: NEED HELP ASAP!!!!   Thu Mar 17, 2011 1:54 am
used that method in the past, works good.
91coupe
PostSubject: Re: NEED HELP ASAP!!!!   Thu Mar 17, 2011 2:32 pm
So ran a boost test and found some very small leaks, fixed and didn't solve the problem so i changed out the rail and the car ran even worse. Put another set of 550's in and ran a little better but revs from 1-2 when idling!
So my theory is i have bad injectors, and a bad second fuel rail?
PostSubject: Re: NEED HELP ASAP!!!!   Thu Mar 17, 2011 3:23 pm
I'm sure you have heard this many times before........but don't use that AFC for tunnin but only for tweaking. Get a rom tune. Plug that SOB right in and youll have a more reliable and better running engine plus timing (important) will be adgujest right compared to doing a clock job. Do you have a wide band? You seem to have some things right your not far from getting that motor running right and reliable. Just wanted to add my cheese.
91coupe
PostSubject: Re: NEED HELP ASAP!!!!   Thu Mar 17, 2011 5:27 pm
I think I have it figured out just need to get some new spark plug wires.
BTW whats a rom tune?
PostSubject: Re: NEED HELP ASAP!!!!   Thu Mar 17, 2011 10:10 pm
So your boost is still at only 5psi?
Jeff G
PostSubject: Re: NEED HELP ASAP!!!!   Thu Mar 17, 2011 10:55 pm
ROM is Read Only Memory.
It's what your ECU references for it's baseline readings.
PostSubject: Re: NEED HELP ASAP!!!!   Mon Mar 21, 2011 12:41 am
So did you get this bad boy moving ?
91coupe
PostSubject: Re: NEED HELP ASAP!!!!   Tue Mar 22, 2011 3:46 pm
Car needed new rotor and cap, new plugs, new wires, and fuel filter!
Anyone in the Milwaukee area do cheap tuning?
NEED HELP ASAP!!!!
