 240 feels a little loose
PostSubject: 240 feels a little loose   Thu Apr 28, 2011 1:58 pm
well i want to drive my car to work and stuff but dont really feel comfortable with the way it handles... going straight it seems fine but when cornering, it feels like the car is loose... hard to explain but seems like the body doesnt flow with the wheels... anyone know what im trying to say??? might be some crappy bushings and i still have to install some on this one too... any clue or help
PostSubject: Re: 240 feels a little loose   Thu Apr 28, 2011 2:00 pm
Does it feel like the front or rear?
PostSubject: Re: 240 feels a little loose   Thu Apr 28, 2011 2:02 pm
like the whole car... i guess maybe a tad bit more in the front maybe??
PostSubject: Re: 240 feels a little loose   Thu Apr 28, 2011 2:03 pm
i guess i dont really want to drive it until this is fixed because it feels kind of unsafe
PostSubject: Re: 240 feels a little loose   Thu Apr 28, 2011 3:09 pm
Probably is unsafe. Ha.
Sway bars connected to the sway bar links?
Tie rod ends loose?
Needs moar info.
crawl underneath the car and inspect the sway bar endlinks and bushings, if those are broke/rotted that might have something to do with it.
PostSubject: Re: 240 feels a little loose   Thu Apr 28, 2011 3:23 pm
check ball joints, tie rods, control arm bushings, etc.
JustTouge
PostSubject: Re: 240 feels a little loose   Thu Apr 28, 2011 4:07 pm
Look at your shocks and see if they leak.
Do the car "jump test" sit on the hatch and bounce up and down see how much the car moves, if its excessive your cars shocks are on the way out. My car would sit and bounce after you would jump off for like 30 seconds, it was crazy.
Mine were the most blown I have ever seen when I bought my car, it was scary to corner in.
cool_kat
PostSubject: Re: 240 feels a little loose   Thu Apr 28, 2011 4:37 pm
Check wheel bearings. Go give all four tires a good shake. Are they moving?
PostSubject: Re: 240 feels a little loose   Thu Apr 28, 2011 6:54 pm
just be a man and drive it haha. jk but yeah i say check ball joints and bearings and see wat happens.
PostSubject: Re: 240 feels a little loose   Fri Apr 29, 2011 6:54 am
ok i will get under the car today and see what i can find... i know that the 240 has some newer stock shocks on it... maybe with 20,000 miles on it???
PostSubject: Re: 240 feels a little loose   Fri Apr 29, 2011 6:58 am
btw any clue what could make my engine light turn on only when i have my foot on the gas pedal?? as soon as i let go it turns off but turns on again if i step on the pedal
PostSubject: Re: 240 feels a little loose   Fri Apr 29, 2011 7:23 am
There's something wrong.
PostSubject: Re: 240 feels a little loose   Fri Apr 29, 2011 10:14 am
i was thinking it was like maybe the maf?? idk yet... runs perfect but the engine light just turns on when the gas pedal is pressed... idk
PostSubject: Re: 240 feels a little loose   Fri Apr 29, 2011 10:18 am
Check codes?
PostSubject: Re: 240 feels a little loose   Fri Apr 29, 2011 2:51 pm
i didnt get a chance to get a look at the car today... got called in early for work.. ohwell more money to spend
PostSubject: Re: 240 feels a little loose   Sun May 01, 2011 12:40 pm
for the light turning on i would check for codes
PostSubject: Re: 240 feels a little loose   Mon May 02, 2011 1:33 pm
it only turns on when the car is moving with the gas pedal pressed
PostSubject: Re: 240 feels a little loose   Mon May 02, 2011 9:03 pm
TPS sensor out of adjustment maybe?
PostSubject: Re: 240 feels a little loose   Tue May 03, 2011 6:52 am
ill check that today... been busy helping this chick with her vw golf...
PostSubject: Re: 240 feels a little loose   Tue May 03, 2011 6:53 am
Brown chicken, brown cow.
PostSubject: Re: 240 feels a little loose   Tue May 03, 2011 6:55 am
lol i didnt get that
PostSubject: Re: 240 feels a little loose   Tue May 03, 2011 6:59 am
70's porn music.
PostSubject: Re: 240 feels a little loose   Tue May 03, 2011 7:00 am
lol... btw isnt it early for people to be using wi240sx??? lol
PostSubject: Re: 240 feels a little loose   Tue May 03, 2011 7:15 am
Too early? This is when I get home from work and snoop around on here lol
