 240 feels a little loose
Go to page : Previous  1, 2
PostSubject: Re: 240 feels a little loose   Tue May 03, 2011 12:46 pm
lol... i im glade i work from 9am-6pm and 5pm-9pm only... im still trying to go back to school so i dont want to many hrs until i get things figured out
PostSubject: Re: 240 feels a little loose   Fri May 06, 2011 5:53 pm
I'm nervous but I'll ask... Did you find anything yet?
PostSubject: Re: 240 feels a little loose   Fri May 06, 2011 9:01 pm
yeah some of the bushings are kinda shot...for the ecu light turning on when i give it gas, i cant seem to figure it out... i checked the ecu but only got code 55 which means everythings good... i also burnt up the old gas and put new 93 in and still runs the same... might sea foam it in a few days and clean up some sensors to see if that fix it... any pacific ones i should look at clean???
PostSubject: Re: 240 feels a little loose   Fri May 06, 2011 9:06 pm
What the hell are you running 93 for in a stock 240? Why waste the money? If I didn't have 11:1 compression, I sure as hell wouldn't.
PostSubject: Re: 240 feels a little loose   Fri May 06, 2011 9:08 pm
to see if it runs any better then it did with crappy ass old gas and guess what it sorta did
PostSubject: Re: 240 feels a little loose   Fri May 06, 2011 9:11 pm
New 87 woulda been just as good. I guarantee it.
PostSubject: Re: 240 feels a little loose   Fri May 06, 2011 9:15 pm
93 on a stock ka dont make no differnce at all. just add some lucas fuel injector cleaner an see what happens
PostSubject: Re: 240 feels a little loose   Fri May 06, 2011 9:21 pm
yeah i was going to sea foam it
PostSubject: Re: 240 feels a little loose   Fri May 06, 2011 9:57 pm
kouki_chee wrote:
any specific ones i should look at clean???
fixed it for you I love you
PostSubject: Re: 240 feels a little loose   Sat May 07, 2011 11:32 am
PostSubject: Re: 240 feels a little loose   Sat May 07, 2011 9:01 pm
pacific is an ocean not something particular, like specific. lol
PostSubject: Re: 240 feels a little loose   Sun May 08, 2011 12:07 pm
Lol same difference. :-p
PostSubject: Re: 240 feels a little loose   Sun May 08, 2011 5:20 pm
lol my bad
PostSubject: Re: 240 feels a little loose   Mon May 09, 2011 11:55 am
haha its all good. i just like giving people a hard time about english from time to time. since a lot of people under the age of 21 or so seems to know how to spell anything or write in non text format lol.
PostSubject: Re: 240 feels a little loose   Mon May 09, 2011 12:17 pm
^^ +1
PostSubject: Re: 240 feels a little loose   Mon May 09, 2011 2:47 pm
lol yeah...
PostSubject: Re: 240 feels a little loose   Tue May 10, 2011 4:41 pm
well i checked the car today and thought i found the problem because the intake wasnt even completely on it... i tighten it on but still has the engine light problem... how do i clean the tps without removing it??? how do i check if its bad or not?? it idles ok i guess... stay sorta steady at 1000rpm and sometime drops to 850 and back up
PostSubject: Re: 240 feels a little loose   Tue May 10, 2011 4:43 pm
You don't clean the TPS. If it's bad, replace it.
PostSubject: Re: 240 feels a little loose   Tue May 10, 2011 9:42 pm
i just checked the tps... i do believe its bad but correct me if im wrong... sorry but i actually bounces alittle between 1350 and 900 rpm... when i unplugged the tps sensor, it still did the same so im assuming it is bad??? if so ill be looking for a good for dirt cheap or else ill just buy a new one...
PostSubject: Re: 240 feels a little loose   Tue May 10, 2011 9:51 pm
it should be .5 volts at closed position. 4.5v full open. slowly sweep it and make sure it reads it smoothly from closed to open.
PostSubject: Re: 240 feels a little loose   Wed May 11, 2011 12:54 am
just put a ls3 on your car and call it a day..
PostSubject: Re: 240 feels a little loose   Wed May 11, 2011 6:04 am
Dude, you need to quit buying used parts if you want anything to run right.
PostSubject: Re: 240 feels a little loose   Wed May 11, 2011 8:17 am
lol yeah...
PostSubject: Re: 240 feels a little loose   Wed May 11, 2011 9:41 am
for sure, i would never buy one of those used, try another friends used one to see if its the problem, then buy a new one.
PostSubject: Re: 240 feels a little loose   Wed May 11, 2011 10:44 am
yeah there isnt much 240 owners where im from
