 2FAS240's 600+HP build
Go to page : Previous  1, 2, 3, 4  Next
PostSubject: Re: 2FAS240's 600+HP build   Wed Feb 23, 2011 6:22 pm
From what I was reading/looking at. It was good.
PostSubject: Re: 2FAS240's 600+HP build   Wed Feb 23, 2011 9:04 pm
i wanted to see the outcome of this project wich looked really promising Rolling Eyes
PostSubject: Re: 2FAS240's 600+HP build   Wed Feb 23, 2011 9:47 pm
he probably blew all his money in vegas and now dont have the cash to take it to the dyno... lol that would suck but yeah i wanna see more!!
2FAS240
PostSubject: Re: 2FAS240's 600+HP build   Wed Feb 23, 2011 10:39 pm
Sorry guys i didn't know you cared so much!! Smile
so i did make it back from vegas alive and actually went back last month for another 2 week stay there haha but back to the car i still had plenty of money to throw it on the dyno but it didn't go as planned 3 hours of tuning time and 500 dollars later it barely started and ran super rough the tuner took my money and said sorry take it home and figure out whats wrong! f**k that guy
So it did start just ran pretty rough my two guesses are either i got a bad ems from aem or something is messed up in my injector wiring... and as we all know it gets super cold in the midwest so i had to put it in storage for the winter so we could use the garage for body work over the winter! but heres what it looked like when it looks like now!!
ENJOY!!
PostSubject: Re: 2FAS240's 600+HP build   Wed Feb 23, 2011 10:54 pm
i would of been pissed... well i guess in a way he did use his time...
PostSubject: Re: 2FAS240's 600+HP build   Thu Feb 24, 2011 12:05 am
yeah, that's a typical shop for ya. sucks to hear kyle but it's almost spring gotta get it done!
PostSubject: Re: 2FAS240's 600+HP build   Thu Feb 24, 2011 6:06 am
At least yours isn't in pieces after dyno time, that sucks.
PostSubject: Re: 2FAS240's 600+HP build   Thu Feb 24, 2011 12:28 pm
^ agreed
2FAS240
PostSubject: Re: 2FAS240's 600+HP build   Thu Feb 24, 2011 8:24 pm
very true! after i rebuilt the internals i broke it in NA for 500 miles to insure there were no issues with it before slapping the turbo on it so hopefully that doesn't happen!
PostSubject: Re: 2FAS240's 600+HP build   Thu Feb 24, 2011 8:28 pm
good idea...
PostSubject: Re: 2FAS240's 600+HP build   Thu May 05, 2011 11:30 am
did you change the ign pick up wheel inside the distributor?
PostSubject: Re: 2FAS240's 600+HP build   Thu May 05, 2011 12:22 pm
As hideous as your gauge pod is on the steering column.... it looks just like what I need! Where did you get that thing??
cool_kat
PostSubject: Re: 2FAS240's 600+HP build   Thu May 05, 2011 7:38 pm
You are running a AEM ems? If so why do you have a MAF and injector resistor pack?
2FAS240
PostSubject: Re: 2FAS240's 600+HP build   Fri May 06, 2011 12:16 am
yep i did change the CAS disc before my tuning session i'm in Puerto Rico till the 14th but when i get back the first thing i'm doing is pulling out my 240 Smile
i bought it from 240sxmotoring.com but i ended up taking it back off cause i didn't care for it to much and it was before i made my center counsel gauge bezel.... i'll sell you mine Smile
i am running an AEM ems and i had that maf from my original engine plan when i was still young and stupid Smile i already have 3.5 bar MAP sensor and AIT on order haha Smile and as for the injector pack you need for low impedance injectors the ems doesn't change anything about that unless i'm crazy??? am i ??? lol
PostSubject: Re: 2FAS240's 600+HP build   Fri May 06, 2011 12:18 am
i street tuned my buddies ka-t with his ams. it was so much better than my power fc Sad
PostSubject: Re: 2FAS240's 600+HP build   Fri May 06, 2011 6:24 am
240sxmotoring, Phase II motrotrend, Frsport, Enjuku
It is a ATI Ezpod. I also have one. I don't thinkthat it is hideous, it works well. And is molded in with the column.
cool_kat
PostSubject: Re: 2FAS240's 600+HP build   Fri May 06, 2011 4:23 pm
Great looking car and nice set up. What cas disc are you running? 24-1?
cool_kat
PostSubject: Re: 2FAS240's 600+HP build   Fri May 06, 2011 4:45 pm
for some reason i thought aem could run low impedance injectors without any resistor pack. Mitsubishi pack?
PostSubject: Re: 2FAS240's 600+HP build   Fri May 06, 2011 4:46 pm
i think they can too. idk for sure though.
2FAS240
PostSubject: Re: 2FAS240's 600+HP build   Fri May 06, 2011 5:25 pm
i'm pretty sure it can't but it is a valid point i mean the injectors seemed to be the issue cause all other sensors were putting at good numbers i havent gotten a chance to test them though i will have to look into it... in the settings you pretty much select which injector you have by brand size and impedance so the ecu would know if it was high or low... but the tuner never said anything when i told him the only changes i made to the wiring so i will have to look into it some more i guess
and ya its the Mitsubishi injector pack
and ya i believe its the 24-1 disc and changed all the settings per aem's instructions for that disc
PostSubject: Re: 2FAS240's 600+HP build   Sun May 15, 2011 10:05 am
The dual fp setup, should the line that the two connect to be bigger? Looks like a bottle neck type effect there. I'm not an expert or anything, just saying. I've never seen hard lines for turbo but nice. Flex on that turbo back exhaust piping would be nice. Just my preference. Lots of good work here.
2FAS240
PostSubject: Re: 2FAS240's 600+HP build   Tue May 24, 2011 10:50 pm
dual setup is going by by i'm ordering an aeromotive tomorrow prolly! there aren't to many people that run hard lines cause it sucks to make them haha but sure looks nice Smile and there will be a flex in there before it goes to far i was under time constraints trying to get it running before winter i will prolly order the flex pipe tomorrow to...
on a good note i just got the car out of storage the other day started troubleshooting and also got my SPL RUCAS, diff bushings and subrframe bushings... and Tein flex coilovers should be here friday!!
2FAS240
PostSubject: Re: 2FAS240's 600+HP build   Tue May 31, 2011 10:56 pm
a few new parts
PostSubject: Re: 2FAS240's 600+HP build   Wed Jun 01, 2011 7:42 am
"They see me rolllan', they hatan."
Baller setup, I especially like the SPL Arms.
Also, baller toolbox! Love the color. I have the same one, but mine is black. I REALLY wish I got a crazy bright color and that green is my fav.
PostSubject: Re: 2FAS240's 600+HP build   Wed Jun 01, 2011 10:51 am
awesome man! can't wait to see it with all the new parts on it.
Page 2 of 4Go to page : Previous  1, 2, 3, 4  Next
