 2FAS240's 600+HP build
Go to page : Previous  1, 2, 3, 4  Next
PostSubject: Re: 2FAS240's 600+HP build   Wed Jun 01, 2011 7:44 pm
awesome man! can't wait to see it with all the new parts on it.
PostSubject: Re: 2FAS240's 600+HP build   Thu Jun 09, 2011 9:52 am
are you running the stock trans? any thoughts of running a z32 instead to handle the power? Also at 600hp you may want to look into better half shafts. The oem tooth picks dont like to last.
2FAS240
PostSubject: Re: 2FAS240's 600+HP build   Tue Jun 28, 2011 11:13 pm
sorry for the delay i've been slacking lately! and was in Canada for a week! but here is where i'm at as of a few hours ago
i'm running the stock trans i have a few spares already, but i have i just installed the Q45 Diff swap so i should be just fine for a while
PostSubject: Re: 2FAS240's 600+HP build   Wed Jun 29, 2011 6:08 am
Lookin good.
PostSubject: Re: 2FAS240's 600+HP build   Wed Jun 29, 2011 6:09 am
powder coated or just painted?
2FAS240
PostSubject: Re: 2FAS240's 600+HP build   Wed Jun 29, 2011 7:18 am
I blasted everything and just reprinted it all with chasis coat turned out pretty good though
PostSubject: Re: 2FAS240's 600+HP build   Wed Jun 29, 2011 7:25 am
It definitely turned out and looks good. Just need toe arms to go with the RUCA.
2FAS240
PostSubject: Re: 2FAS240's 600+HP build   Wed Jun 29, 2011 8:47 am
I'll do some more suspension mods once she's running and driving I just did the main things for now I'm putting the front coilovers in tonight and working on the motor issues after that I know I've said it like 10 times but maybe it will be running in a week or 2 ??? Lol
PostSubject: Re: 2FAS240's 600+HP build   Sun Jul 24, 2011 7:11 pm
Well, is it running?? Question
2FAS240
PostSubject: Re: 2FAS240's 600+HP build   Sun Jul 24, 2011 10:21 pm
man you must be stocking me haha i literally just got it all put back together a few hours ago and loaded my new start up cal and guess what.... i still have an injector issue so i pulled the whole harness back out unwrapped it all double checked all my wires and all looks to be good so it leading me to think i somehow have a faulty resister pack i have a honda one laying around in the garage that i'm gonna toss in tomorrow to check i think should be close to the same resistance
PostSubject: Re: 2FAS240's 600+HP build   Sun Jul 24, 2011 11:55 pm
stocking?
oh STALKING! Wink
2FAS240
PostSubject: Re: 2FAS240's 600+HP build   Wed Jul 27, 2011 9:04 pm
lol so my spelling is a little off Smile i had a late night haha so i started the 240 up last night and still runs like piss.... did some troubleshooting had an injector wire messed up and then its basically running off of one cylinder so took a look at the cap and rotor pretty f'ed up got the rotor waiting on the cap if it runs like a champ because of a frickin cap and rotor i'm going to sh*t a brick.....................................................................
PostSubject: Re: 2FAS240's 600+HP build   Wed Jul 27, 2011 9:20 pm
shitting a brick would hurt!! i hope that doesnt happen haha. good luck!
PostSubject: Re: 2FAS240's 600+HP build   Wed Jul 27, 2011 9:44 pm
i never noticed the picks of your an lines, those hard lines are sick for turbo feed. If i may make a suggestion though. I think your going to have issues with your maf being so close to your turbo and your valve cover vent not routed to your turbo intake. I did the same thing and i had crazy fluctuation in A/F ratios until i fixed it. 10" away from the turbo min for the maf sensor. Thats per the guys at Jim Wolf. Sick build so far though. Keep up the ka love.
2FAS240
PostSubject: Re: 2FAS240's 600+HP build   Thu Jul 28, 2011 7:29 am
O Dang apparently I didn't post that update on this forum! I already tossed that haha I switched to a MAP sensor ill post a picture up in a little bit of my new turbo intake pipe! Waiting on my cap to get here tonight so we will see if it works
2FAS240
PostSubject: Re: 2FAS240's 600+HP build   Thu Jul 28, 2011 7:33 am
The iat isn't staying there either I already got another bung.and am putting it pre throttle body
PostSubject: Re: 2FAS240's 600+HP build   Thu Jul 28, 2011 7:37 am
very nice, a map sensor is a ka-t best friend, rite next to an oil cooler, big ass radiator, and swirl pot system. Keeping it cool is going to be your biggest fight.
cool_kat
PostSubject: Re: 2FAS240's 600+HP build   Thu Jul 28, 2011 8:36 pm
Are you playing with the aem at all? Are u still running the resistor packs? Just wondering if the may be messing you up. Im prety sure you dont need the packs not with the AEM. Might be something to look into. New cap and rotor, any other ignition upgrades?
PostSubject: Re: 2FAS240's 600+HP build   Fri Jul 29, 2011 1:15 pm
i had my IAT in the same place for about a week. my a/f ratios were crazy! driving in town vs the hwy the a/f would fluctuate by more than 2 points! i wouldnt even bother putting it there now. just take the extra time to move it now lol.
2FAS240
PostSubject: Re: 2FAS240's 600+HP build   Fri Jul 29, 2011 9:07 pm
yep i have been playing with the AEM a little bit here and there printed off the nice 217 page manual and slowly been making my way through it... i'm still running the resister pack it is required to have on a 240 to run low impedance injectors... but this is not true for all AEMs some do include the drivers needed internally usually just for vehicles that came stock with low impedance injectors.
and ya i put there and then a day later i was like hmm what the hell did i do that for i wrote under that picture that it wasn't staying there i'm gonna put it somewhere on my coldpipe towards the throttle body Smile i got the bung the other day in the mail
PostSubject: Re: 2FAS240's 600+HP build   Fri Jul 29, 2011 10:14 pm
yeah i saw that. i was just trying to tell you not even to use it there for a day or two lol. once you move it your tune will change quite a bit. on my car i just put it right in front of my throttle body. isnt as good as in the intake manifold but i dont have many issues with fluctuations.
2FAS240
PostSubject: Re: 2FAS240's 600+HP build   Fri Jul 29, 2011 11:06 pm
I don't know that I would put on the intake manifold we just finished a s2000 last week and the tune requested that we move from the ma.fold to pre throttle body
PostSubject: Re: 2FAS240's 600+HP build   Fri Jul 29, 2011 11:56 pm
the directions in my power fc said to put it in the intake. so ive just gone by that. im sure there are reasons for both ways
PostSubject: Re: 2FAS240's 600+HP build   Sat Sep 22, 2012 8:39 am
I just love looking at fresh built motors. Just a suggestion, look into an Apexi or K&N intake filter, preferably apexi because they are dry type and one of the better performing filters. Those hks or hks style foam filters do not filter very well. Everything looks great though!
2FAS240
PostSubject: Re: 2FAS240's 600+HP build   Mon Oct 01, 2012 10:33 am
Wow i haven't updated this forever but I did finish the car and get it running made 325 on wastgate pressure went back a week later and made 411 with spark blowout after that so I decided to do the LS2 coil upgrade to get rid of my spark blow out so here are pictures of that and a few other little upgrades to the car. going in for another tune tomorrow hopefully all goes well and i come out around 450hp to end the year.
Wiring looks like crap but I will be redoing it all when i put my Xcessive Intake on.
I'll post up a dyno sheet tomorrow hopefully!
Page 3 of 4Go to page : Previous  1, 2, 3, 4  Next
