 bad waterpump or t stat??
ttallin
PostSubject: bad waterpump or t stat??   Fri Jul 08, 2011 7:37 pm
so yesterday was leaving taco bell and my car started overheating 89 sohc 170k. it was boiling water and causing it to escape out the breather on the overflow tank. i think its the water pump or tstat. not 100% but i guess in the morning ill rip the pump out and put new one in seeing i dont have a belt driven fan or fan shroud it should only take 30min to do it. theres no white smoke pouring out my exhaust so i dont think it would be the hg.
PostSubject: Re: bad waterpump or t stat??   Fri Jul 08, 2011 8:02 pm
i would start smaller, a tstat is cheaper and should be easier to do, you can always take out the thermo and put it in a pot of boiling water and see if it opens or not to test if its bad.
PostSubject: Re: bad waterpump or t stat??   Fri Jul 08, 2011 8:21 pm
That's what my old coupe (your old coupe) did it was the ts . It was stuck closed. I took it out and ran without it with no problems just didn't have heat lol
ttallin
PostSubject: Re: bad waterpump or t stat??   Sat Jul 09, 2011 12:12 am
i think i might just take t stat out and c if that works i mean 22 bux for a h20pump aint shit
PostSubject: Re: bad waterpump or t stat??   Sat Jul 09, 2011 12:46 am
if its the water pump, you should be able to hear a weird noise coming from it. so it would be the thermostat.
PostSubject: Re: bad waterpump or t stat??   Sat Jul 09, 2011 1:55 am
those water pumps arent the greatest. ive had two fail. either way both are cheap fixes and you might just want to do both.
PostSubject: Re: bad waterpump or t stat??   Sat Jul 09, 2011 12:35 pm
^^^+1
ttallin
PostSubject: Re: bad waterpump or t stat??   Sat Jul 09, 2011 10:11 pm
well took t stat out and ran my fan to a SWITCH RUNS GOOd HOPE I MAKE IT TO KENOSHA tomarrow
