 Trunk not opening?
jaybaum96
PostSubject: Trunk not opening?   Thu Jul 14, 2011 11:34 am
So ive had the car for almost 2 weeks now, and 2 days ago i went to go open my trunk and - nothing. I pulled the lever, the trunk didnt open. Last week i took the spoiler off and did notice the trunk would almost fly open, rather than have to be lifted. With the backseat down you can hear the cable moving, but the trunk doesnt open. What could this be? Could the cable have simply came off the latch inside the trunk?
PostSubject: Re: Trunk not opening?   Thu Jul 14, 2011 11:51 am
Sounds like the easiest and first thing to check.
PostSubject: Re: Trunk not opening?   Thu Jul 14, 2011 12:10 pm
Does the handle retract? Cause if its not springing back to the middle possition then it either broke or fell off. If thats not the issue, it could just be a missalignment problem. latch comes lose and cant free itself. Looks like its time to drop the back seat and crawl around.
PostSubject: Re: Trunk not opening?   Thu Jul 14, 2011 12:18 pm
ive popped open an s13 one from inside the trunk before. you might have to do that
hurleyboy00
PostSubject: Re: Trunk not opening?   Thu Jul 14, 2011 12:44 pm
From inside the car drop the seat down and reach in to the latch. There is a manual lever to pop the trunk. Pop it. After that I bet it will open no problem. Sometimes the latch gets stuck. Has happened to me on my s14.
PostSubject: Re: Trunk not opening?   Thu Jul 14, 2011 1:26 pm
what hurley boy said. somestimes the cable for the trunk will get streched out/pinched on something and wont let it open..... ask me how i know. haha
PostSubject: Re: Trunk not opening?   Fri Jul 15, 2011 10:59 am
How do you know nick?
PostSubject: Re: Trunk not opening?   Fri Jul 15, 2011 1:11 pm
There is a "switch" on the S14 trunk latch that will disable the cable action so someone can't break into the trunk by reaching in the window. I don't remember exactly what it looked like but that happened to me years ago.
jaybaum96
PostSubject: Re: Trunk not opening?   Mon Jul 18, 2011 11:34 am
where is this switch exactly, litterally on the latch itself?
PostSubject: Re: Trunk not opening?   Mon Jul 18, 2011 11:35 am
on the latch in the trunk, you will have to look behind the carpet if memory serves. Its part of the latch assembly on the part that's not attached to the lid.
jaybaum96
PostSubject: Re: Trunk not opening?   Mon Jul 18, 2011 11:44 am
just went outside and tried it, it worked. Thanks alot!!
PostSubject: Re: Trunk not opening?   Mon Jul 18, 2011 11:52 am
Sweet, you are welcome.
Trunk not opening?
