 95 240sx "the midnight mistress"
Go to page : Previous  1, 2, 3, 4, 5 ... 9 ... 14  Next
PostSubject: Re: 95 240sx "the midnight mistress"   Sat Sep 10, 2011 5:37 pm
to do list.
clean motor
due main seal
and pulleys after paint( pink)
engine front cover paint(pink)
engine brackets paint( purple)
new motor and trans mounts
new alternator
plugs
change distributor out for s14
swap oil pan and do gasket paint (purple)
valve cover crome hello kitty and pink
PostSubject: Re: 95 240sx "the midnight mistress"   Sat Sep 10, 2011 6:59 pm
Look at chasebays for a smaller booster and tucked harness/lines. Im proud of you that you got the motor and trans out. Soon my friend, i will be calling you to tell you that im on my way to slap the new motor in. Not next weekend, but the friday after may be when.
PostSubject: Re: 95 240sx "the midnight mistress"   Sat Sep 10, 2011 7:29 pm
thanks , ill behonest man i had a lack of faith in my self but like josh ( the freak) told me , u got to push and be a get it done kinda guy. and its got me thinking . why bitch up to difficulty when you can just go hard and make progress .
and ill def be looking foward to you coming down lol ill have to have some food and drinks. but before it goes in paint is a must.
PostSubject: Re: 95 240sx "the midnight mistress"   Mon Sep 12, 2011 9:19 am
i hear ya man. Thats how i learned everything i know about cars. Just gotta get your hands dirty and bust some knuckles. Let me know when your done painting and ill head out your way to help with the re-assembly.
PostSubject: Re: 95 240sx "the midnight mistress"   Mon Sep 12, 2011 12:18 pm
Yup. Hope fully she'll be running in 2 months and ill grab some overs from traffic and Spacer. Just need some Coilovers and boom down to paint
PostSubject: Re: 95 240sx "the midnight mistress"   Wed Sep 14, 2011 3:41 pm
ok so im looking for some after market parts to support 300hp NA> yes i said NA so far im missing
valve seats
lifters
buckets
guide
tensioner
timing chain/belt
shims
stoppers
rocker arms
any advice on were to look is appriciated
PostSubject: Re: 95 240sx "the midnight mistress"   Wed Sep 14, 2011 7:01 pm
i guess i got you on the high hp n/a kick last time didn't i
PostSubject: Re: 95 240sx "the midnight mistress"   Wed Sep 14, 2011 7:02 pm
So.... What else are you getting to make 300 hp?
PostSubject: Re: 95 240sx "the midnight mistress"   Wed Sep 14, 2011 7:06 pm
300HP N/A KA is gonna need a few more parts. light high compression pistons. aftermarket rods. Camshafts/etc etc. and honestly either need a e85 tune or race gas to run a compression ratio as high as you will need to run 300hp.
PostSubject: Re: 95 240sx "the midnight mistress"   Wed Sep 14, 2011 7:09 pm
well assuming i have reaserch correctly it take a full head build and blue print. i have to stroke the the block(gigidy) and it all falls on fuel and tune i figure at the end of it all id make 280 on 91 octane.....i hope LOL ill post the list of parts as soon as i have mated parts that will function . if al odds end ill boost!!
PostSubject: Re: 95 240sx "the midnight mistress"   Wed Sep 14, 2011 7:14 pm
Stroke to what, 3.0L?? I'm not saying it's not possible, I just think you may be overly optimistic.
PostSubject: Re: 95 240sx "the midnight mistress"   Wed Sep 14, 2011 7:18 pm
so far , jim wolf adj. cams ,BC cams 272/272 ,BC retainers/valves 31.80mm ex/37.10mm IN ,shims and buckets,bronze guides and copper seals,BC springs seat. 1.400@73lbs,open 0.950@155lbs <- top end
BC stroker +5 over ,tomei oil pump,and a turbo set oil pan.
tune will be morethen likely a dyno with 255pump and sr20 injectors with a true CAI on msd blaster, light fly wheel ,j30 diff,aluminum drive shaft and hopefully a turbo trans if i can find one that bolts up .....
my guess 250hp full contact on the ground with instant response.
again STILL RESEARCHING
PostSubject: Re: 95 240sx "the midnight mistress"   Wed Sep 14, 2011 7:29 pm
i guess im trying to build a solid block at stock form(sort of speak) and see what can happen when its done with a set goal in mind , plus its a long term thing ill build the pulled motor and drop in the donor for now.
PostSubject: Re: 95 240sx "the midnight mistress"   Wed Sep 14, 2011 7:35 pm
i think Brian Crower made/makes a 2.6L or is it a 2.8L stroker kit for the KA might want to look into that.
EDIT - 2.6L
http://www.xratedparts.net/brian_crower/brian_crower_stroker_kit/bc0219/i-149105.aspx
Look into http://www.rebelloracing.com/index.htm they used to build N/a KA's in the 260-280hp range.
PostSubject: Re: 95 240sx "the midnight mistress"   Wed Sep 14, 2011 7:38 pm
well ive always had respect for chevy's and ford's and the ability to make amazing numbers just dedicating time to look at all aspects of power , that can be achivied . the KA is so basterdized i just think its worth making a solid KA and see were we stand when the dust settles.
will i make 300HP..........who knows! but it will be a good learning for me and ill feel great when i achive it be 210 or 280.
PostSubject: Re: 95 240sx "the midnight mistress"   Wed Sep 14, 2011 7:39 pm
yeah they do /but id like to see what i can get stock block before i go stroke.
PostSubject: Re: 95 240sx "the midnight mistress"   Wed Sep 14, 2011 7:40 pm
i had a question can i adapt a ka24e upper intake to a lower 24de intake?
PostSubject: Re: 95 240sx "the midnight mistress"   Wed Sep 14, 2011 7:43 pm
id like to lighting the load and improve response on drive train.
PostSubject: Re: 95 240sx "the midnight mistress"   Wed Sep 14, 2011 7:56 pm
i have no idea on something like that. you might want to just have someone make you a custom intake plenum. or look on ebay? i think i've seen some on there.
PostSubject: Re: 95 240sx "the midnight mistress"   Wed Sep 14, 2011 8:07 pm
cool thanks
PostSubject: Re: 95 240sx "the midnight mistress"   Wed Sep 14, 2011 11:32 pm
Wow such wise words... Im gonna do that anf not give up on my card N trade them off... Ohh wait i have been doing that!!! Yah me!!!
PostSubject: Re: 95 240sx "the midnight mistress"   Thu Sep 15, 2011 5:49 am
huh
PostSubject: Re: 95 240sx "the midnight mistress"   Thu Sep 15, 2011 11:18 am
91 octane is going to cause a bunch of unwanted detenation. My built ka had huge problems until i went with race gas and it cleared up instantly.
272/272 cams are going to be laggy, check out the xcessive engineering oil pan(awesomeness) with an sr moroso pan. Stroker wont be necessary, but will get you the numbers you want with awesome torque numbers to go with them. The 255 fuel pump wont be enough (i would recomend a pair of them or a pair of bosch 044's) Stock sr injetcors are 370's. Which will be way to small for you. I would look around the 850 range to be safe (can always tune them down). For valve train stuff, look into the JWT 350z transplant they did in matt powers formula d ka-t (hes now ls3). Xcessive also make adaptor plates to mate a z32 trans to a ka.
Stock bore is too small, your going to have to bore it out at least .020 over. Build the donor motor and just throw a trans and new gaskets on the old motor. Donor has way less miles.
a broken block, there, i answered your question, lmao, stroke it, and stroke it good. No need to do the job twice and spend the money twice.
nope, wont fit, bolt pattern and hole location is different(a lot of unneccesary work for extra restriction) .
No need for a custom manifold, xeccesive makes one of those as well that flows very nicely for turbo cars, dont see why it wont help an N/A car. But if it were me, and this is just a suggestion, go with ITB's (individual throttle bodies). Can be a pain in the ass to get them all tuned the same, but help make enormous numbers. But your going to have to make a custom manifold.
Text me if you have any more ideas. This could be a sick setup if done rite. But not the easiest on your wallet.
Challenge: Biggest hurdle your going to have, is figuring out how to keep it from over heating. Ka's are very good at that.
PostSubject: Re: 95 240sx "the midnight mistress"   Thu Sep 15, 2011 1:53 pm
go 2.6l with 12.5:1 compression and get lots of porting done. the ka doesnt rev that high so maybe stick with a 264 ish cam. you might not make 300hp but your torque is going to be great.
just my 2c if anyone cares.
PostSubject: Re: 95 240sx "the midnight mistress"   Thu Sep 15, 2011 1:58 pm
Dame! We need to put our creative minds to work for me With all the brilliant diverse minds on this fourm ilend up with thye mother of all sleepers.
Page 4 of 14Go to page : Previous  1, 2, 3, 4, 5 ... 9 ... 14  Next
