 turbo surge and white smoke
PostSubject: turbo surge and white smoke   Wed Sep 01, 2010 5:48 pm
So I got my sr running
I am wondering the easiest way to stop the surging
And I have a small ammount of white smoking coming from exhuast..
Only when I start off in first...
And when I. Slow down, small amount
Any advice?
I was thinkin I need new turbo?
PostSubject: Re: turbo surge and white smoke   Wed Sep 01, 2010 8:52 pm
i had white smoke on decel when my stock twins were going back.... the percision fixed that Smile
way to stop surging... get a new turbo w/ an anti surge housing Smile or see if you can get one for ur turbo
PostSubject: Re: turbo surge and white smoke   Wed Sep 01, 2010 9:23 pm
So tell your wonderful boyfriend to search tho cool websites for me please thanks
PostSubject: Re: turbo surge and white smoke   Wed Sep 01, 2010 9:28 pm
White smoke = Coolant / Water
Black smoke = oil
Blue smoke = gas
so with "white smoke" there is a water/coolant getting into your motor. Liz had a blackish/blue smoke that made it look grayish.
compressor surge is a little harder to pinpoint. but liz has a sort of correct idea. usually it's from a too small of turbo for the engine to compress air into (sometimes why it happens at 1/2 throttle) thats why you can get a anti surge housing on turbos now to get rid of it. But in your case being on a stock turbo, i bet the surge is coming from something else. weather the "fins" are bent/broke/cracked or if there is something restricting the exahust flow or the intake flow. (compressor surge is usually caused by a Fast/Slow/Fast/Slow/etc movement of the turbine wheel) Check into seeing if your wastegate is bad on your sr or even a bad bov i've heard can cause it.
PostSubject: Re: turbo surge and white smoke   Wed Sep 01, 2010 9:30 pm
PostSubject: Re: turbo surge and white smoke   Wed Sep 01, 2010 9:53 pm
So are you saying head gasket? Bc I had a head gasket gone on my taurus when I was in highschool, its no where near like that... so how else is coolant going there?
PostSubject: Re: turbo surge and white smoke   Wed Sep 01, 2010 10:08 pm
there might be a little crack. sucks to say, maybe someone else can chime in.
PostSubject: Re: turbo surge and white smoke   Wed Sep 01, 2010 10:22 pm
time for a new motor LOL
PostSubject: Re: turbo surge and white smoke   Wed Sep 01, 2010 10:28 pm
Now crack your talking gasket, not the head itself right?
PostSubject: Re: turbo surge and white smoke   Wed Sep 01, 2010 10:44 pm
could be a little crack in the head, could be a bad HG. could be alot of things.
PostSubject: Re: turbo surge and white smoke   Wed Sep 01, 2010 11:01 pm
Could be let's not say anything and I sell it and boost my ka...
Topic closed =)
