 How to tell Differance between KA and SR trans
PostSubject: How to tell Differance between KA and SR trans   Thu Sep 01, 2011 9:44 pm
is there an easy way to tell the differance between sr and ka trans?
i Know that 5th gear is differant other than that i dont really know. my car runs 2700rpm at 65mph in 5th with a kaaz 2waay diff
PostSubject: Re: How to tell Differance between KA and SR trans   Fri Sep 02, 2011 3:31 am
I can tell you both my ka's were like 55 at that rpm
PostSubject: Re: How to tell Differance between KA and SR trans   Fri Sep 02, 2011 7:57 am
5speed SR and KA are similar. OD gear is 0.838 for the sr and 0.759 for the ka according to a forum I read. You can use the KA trans with an SR bellhousing.
PostSubject: Re: How to tell Differance between KA and SR trans   Fri Sep 02, 2011 9:18 am
VNG704 wrote:
5speed SR and KA are similar. Final gear is 0.838 for the sr and 0.759 for the ka according to a forum I read. You can use the KA trans with an SR bellhousing.
tru but they are a pain in the ass to change the bellhousing, it sucked when i had to do mine.
PostSubject: Re: How to tell Differance between KA and SR trans   Fri Sep 02, 2011 11:45 am
eh ive done it twice. i broke 2nd gear right off the counter shaft on my sr trans. so now i have an s14 trans with the sr bell housing.
PostSubject: Re: How to tell Differance between KA and SR trans   Sat Sep 03, 2011 8:14 am
For the guys that have done that trans swap, what's the difference if any in driveability, performance, ...anything?
PostSubject: Re: How to tell Differance between KA and SR trans   Sat Sep 03, 2011 11:29 am
its not even really noticable. they are only slightly different.
PostSubject: Re: How to tell Differance between KA and SR trans   Sat Sep 03, 2011 4:46 pm
Swapping the the sr trans with a ka vise versa, you wont notice much of a difrence at all. It's fairly simple excpet its easy to pop the gear when sliding the bell housing in. Gets annoying.
