 body work ???
PostSubject: body work ???   Fri Sep 09, 2011 10:53 pm
Ok well i decides to do some bodywork on my junk looking 240sx... Now my question is can i wetsand my primer coat as it has tons of orange peel.... Its my first time using a gun and i think it turned out quite good even with all the orange peel.... Im still trying to tune my gun but i dont want to waste any of my paint as its expensive.... Im sure ill have more questions but until then, can i wet sand my primer???
PostSubject: Re: body work ???   Fri Sep 09, 2011 11:10 pm
Yes, you can. But after sanding, make sure you wipe it clean with acetone before spraying again.
PostSubject: Re: body work ???   Sat Sep 10, 2011 1:17 am
Ok... Would i need a guide coat???
PostSubject: Re: body work ???   Sat Sep 10, 2011 3:58 pm
That's completely up to you on how you decide to do it. As far as "need?" No. If the sanding goes well, the guide coat would be a waste of money. Even though it is kinda cheap and can be useful depending on the area you're doing.
When I used to do body work, I just use a small fluorescent light to check for any waves. Hold it at different angles to make sure everything's smooth. If its not smooth, the wave will cast shadows.
Good luck!
PostSubject: Re: body work ???   Sun Sep 11, 2011 8:23 am
Cool thanks man... Anybody close to point want to give me a hand on this... Lol im doing the whole car... Pass rear qp is done already
PostSubject: Re: body work ???   Sun Sep 11, 2011 9:57 am
Is body work the only thing wrong with your car right now? What else you gotta do to it?
PostSubject: Re: body work ???   Sun Sep 11, 2011 6:22 pm
Well i got some body work and have to install my upper timing chain, es bushings and welded diff... Thats really it... Well i also have a battery drainage issue and my headlights wont go down
PostSubject: Re: body work ???   Mon Sep 12, 2011 7:47 am
s13 head lights look gay down anyways kouki keep em up and drop that frame. oh and pignose
PostSubject: Re: body work ???   Mon Sep 12, 2011 9:51 am
wet sanding primer is only if you want your color to look perfect. If your ok with an "ok" paint job and not going show quality. Then scuff, clean, and spray color. More prep work you put into the car before color, the better it will look. Im not saying wet sand with 1400 grit but something to get it smooth and eliminate any orange peel/streaks/runs/etc. Acetone works good for cleaning the surface before paint, but you can do better with a tack cloth. They dont leave any residew. Then just scuff lightly with a red scotch-brite pad, clean/wipe it down and shoot the color. If youve prep'd it rite, the only other time youll wet sand again is after you lay down clear. Yes you can wet sand the paint, but if primer is prep'd, the paint will lay down smooth and even. And you wont have to color sand it.
PostSubject: Re: body work ???   Mon Sep 12, 2011 5:47 pm
lol i am going pignose... im in the process of fixing my pignose bumper and still looking for a driver side qp
PostSubject: Re: body work ???   Mon Sep 12, 2011 6:38 pm
Disconnect the headlamp motor wires/plugs and see if that fixes your drainage problem. I'm with j240sxxx on the lights staying up. If our opinion matters, that is.
PostSubject: Re: body work ???   Mon Sep 12, 2011 9:31 pm
Lol yeah but i kinda like having the sleepy eye look... Ill try to see if that fixes the problem
PostSubject: Re: body work ???   Mon Sep 12, 2011 11:58 pm
I'm just saying. If it fixes the drainage problem, then you found the culprit. So you know what to fix/replace. Good luck.
PostSubject: Re: body work ???   Tue Sep 13, 2011 10:44 am
thanks..
body work ???
