 Anybody know for sure how much the stock S14 fuel tank holds?
PostSubject: Anybody know for sure how much the stock S14 fuel tank holds?   Wed Sep 14, 2011 8:39 am
I ran my car basically out of fuel yesterday (on purpose) so I could fill with E85. I was only able to fit 13 gallons in. I am reading online the stock tank holds 17 but I am skeptical. I know the fuel pickup isn't ideal with the walbro and sock but there can't be 4 gallons lying in the bottom of the tank can there???
I am going to run a few tanks of E85 through it in an effort to dilute out the pumpgas but if I am leaving 4 gallons at a time in the tank it's going to take awhile.
Thanks
PostSubject: Re: Anybody know for sure how much the stock S14 fuel tank holds?   Wed Sep 14, 2011 9:32 am
there could be... the 13 tanks do go alot lower than where the pumps sit, idk for s14's though
PostSubject: Re: Anybody know for sure how much the stock S14 fuel tank holds?   Wed Sep 14, 2011 9:51 am
When mine is stalling because it's so empty, I can only fit 14 in it.
PostSubject: Re: Anybody know for sure how much the stock S14 fuel tank holds?   Wed Sep 14, 2011 9:52 am
That's what I expected to hear.... I figured max 15 gallons
Jim, do you have a walbro pump in your car too?
PostSubject: Re: Anybody know for sure how much the stock S14 fuel tank holds?   Wed Sep 14, 2011 12:07 pm
s14 have a 14 gallon tank, s13's have a 12 (15 if you use a funnel and dont pay attention to what your doing)
PostSubject: Re: Anybody know for sure how much the stock S14 fuel tank holds?   Wed Sep 14, 2011 12:09 pm
^ that is what I had expected to hear. Do you know from experience? It's important that I know for sure so I can figure out when the amount of gas in my tank vs Ethanol is at an acceptable level to tune.
Thanks.
PostSubject: Re: Anybody know for sure how much the stock S14 fuel tank holds?   Thu Sep 15, 2011 4:28 pm
Why yes I do sir.
PostSubject: Re: Anybody know for sure how much the stock S14 fuel tank holds?   Fri Sep 16, 2011 8:30 am
The pump pickup isn't ideal, and it could possibly be leaving fuel in the bottom of the tank FYI. I know you wanted more capacity, it wouldn't hurt to pump out the tank with the fuel pump and pull the lid to see how much is still lurking in there.
