 Superlight S13 - No 56K!
Go to page : Previous  1 ... 5, 6, 7 ... 13 ... 20  Next
PostSubject: Re: Superlight S13 - No 56K!   Wed Feb 01, 2012 3:27 pm
You made money on what you sold? Nice job. been there done that.
PostSubject: Re: Superlight S13 - No 56K!   Wed Feb 01, 2012 5:50 pm
not vuching but hate to see new parts rust u know!
PostSubject: Re: Superlight S13 - No 56K!   Wed Feb 01, 2012 5:52 pm
Aluminum, rust?
PostSubject: Re: Superlight S13 - No 56K!   Sun Feb 12, 2012 6:38 pm
SR is on it's way, along with basic supporting parts.
PostSubject: Re: Superlight S13 - No 56K!   Sun Feb 12, 2012 7:03 pm
speed_demon wrote:
Aluminum, rust?
i was being a smart ass
PostSubject: Re: Superlight S13 - No 56K!   Sun Feb 12, 2012 7:22 pm
Me too. Very Happy
Have you seen this yet? Found it on some random forum. Pretty sweet.
PostSubject: Re: Superlight S13 - No 56K!   Sun Feb 12, 2012 7:33 pm
cf, washers? or are the bolts cf too?
PostSubject: Re: Superlight S13 - No 56K!   Sun Feb 12, 2012 7:34 pm
i realized how dumb that sounds now. sorry. lol
PostSubject: Re: Superlight S13 - No 56K!   Sun Feb 12, 2012 7:48 pm
wow sick! i want, u plan making some?
id say $20 a bag of 50
PostSubject: Re: Superlight S13 - No 56K!   Sun Feb 12, 2012 7:49 pm
just washers i mean, but if u offered it with the bolts to it be sick 10 washers 10 bolts 20$
PostSubject: Re: Superlight S13 - No 56K!   Sun Feb 12, 2012 7:59 pm
They do make composite bolts, but their use seems limited.
The CF washers are mainly for appearance. They look very easy to make, and I am setting up my work table and will make some washers for myself tonight.
With 3 ply CF, the material cost alone for 50 would be more than $20. Just sayin..
Also very interested in finding a company that will make me a CF valve cover.
PostSubject: Re: Superlight S13 - No 56K!   Sun Feb 12, 2012 8:21 pm
all you'd need is a sheet a carbon fiber and cover it in masking tape then use a hole saw....but yeah....i was gonna say...50 for $20 is a losing venture...lol
PostSubject: Re: Superlight S13 - No 56K!   Sun Feb 12, 2012 9:02 pm
a sheet dont cost shit to make and u will get far more then 50 out of a sheet, hell if u get 150 out of a sheet u just made $60 off ur work .
PostSubject: Re: Superlight S13 - No 56K!   Sun Feb 12, 2012 9:06 pm
make a mold of ur cover and there u go , carbon fiber valve cover.
PostSubject: Re: Superlight S13 - No 56K!   Sun Feb 12, 2012 9:42 pm
There is a fuck ton to a valve cover. Sr covers are baffled so youd need to add that, on top of inserts for the pcv and breather vents. On top of all of that you need to re-enforce where the cover bolts to the head.
PostSubject: Re: Superlight S13 - No 56K!   Sun Feb 12, 2012 9:45 pm
Be better off just making a cover for the cover. Just for looks
PostSubject: Re: Superlight S13 - No 56K!   Sun Feb 12, 2012 10:05 pm
Refer to thread title and build intentions.
Also, CF valve covers are complex pieces of art. They are not easy to make.
PostSubject: Re: Superlight S13 - No 56K!   Sun Feb 12, 2012 11:28 pm
agreed.
PostSubject: Re: Superlight S13 - No 56K!   Mon Feb 13, 2012 3:13 am
they are easy with the rite software and technology. Make a thick cabon block, then cnc it, cover in extra resin to bring back the shine and done. Now all you need is someone to make you a 3d model to be programmed into a mill.
PostSubject: Re: Superlight S13 - No 56K!   Mon Feb 13, 2012 9:11 pm
Putting some thought to how I will mount the accessories. I'm thinking of placing the alt where the AC compressor originally would be. If I'm keeping the power steering I'm going to have another bracket to figure out as well. My main thought being Simplify, then add lightness.
FWD SR20DE - Notice how the alt mount is more compact - I like this design.
RWD SR20DET with aftermarket pulleys, stock acc. locations.
Engine is scheduled to arrive tomorrow, the 14th.
PostSubject: Re: Superlight S13 - No 56K!   Mon Feb 13, 2012 9:53 pm
valentine gift uh
PostSubject: Re: Superlight S13 - No 56K!   Tue Feb 14, 2012 4:27 pm
It looks like you would need to make a custom coolant inlet to clear the alternator in that position. Then you will also need to get a different hose to make it from the radiator to that location. That seems like a lot of screwing around to pull the alternator up and in a inch or two. Besides the stock location is lower which will give a lower roll center. Not that the 6-8 lb. alternator is going to make that much of a difference unless you are building a full on race car.
PostSubject: Re: Superlight S13 - No 56K!   Tue Feb 14, 2012 5:01 pm
You did see where I said "I'm thinking of placing the alt where the AC compressor originally would be", right? bounce
My thinking was that I could make a combination alt/ps bracket to do away with both cast iron units. Otherwise running both with heim joint ends looks possible as well. The engine was rescheduled for delivery tomorrow, so I will have to take a look for myself.
PostSubject: Re: Superlight S13 - No 56K!   Tue Feb 14, 2012 6:50 pm
I'm hemorrhaging money on this car. Working on selling my winter truck so I can buy more stuff I don't really need. Laughing
When it's back together the car will be epic. I know I can do under 2K lbs with some creativity.
PostSubject: Re: Superlight S13 - No 56K!   Tue Feb 14, 2012 7:02 pm
no it won't. you don't understand what roll center is. center of gravity yes. RC no.
Page 6 of 20Go to page : Previous  1 ... 5, 6, 7 ... 13 ... 20  Next
