 Superlight S13 - No 56K!
Go to page : Previous  1 ... 10 ... 16, 17, 18, 19, 20  Next
PostSubject: Re: Superlight S13 - No 56K!   Fri May 11, 2012 4:11 pm
MIG welding, with practice, is about as easy as it gets. Even I can do it!
PostSubject: Re: Superlight S13 - No 56K!   Fri May 11, 2012 10:24 pm
if you can get a hold of a welder or want to bring the car down to me, i can weld it for you. I just need to finish wiring up my garage before i can do it here.
PostSubject: Re: Superlight S13 - No 56K!   Fri May 18, 2012 6:57 pm
Thanks for the offer. You are a helluva drive from GB though.
I'm working on buying a shell from Kouki Chee to use for parts. That way I would basically be able to make a complete car with a straight front end again. Laughing
Once the car is finished I'm planning to eventually sell it and put the money towards something I can make faster. It'll be epic.
I'll set up a poll of my choices later on down the line and see what you guys think.
PostSubject: Re: Superlight S13 - No 56K!   Fri May 18, 2012 8:16 pm
anything can be made fast. its just whatever car you like the most.
PostSubject: Re: Superlight S13 - No 56K!   Sat May 19, 2012 2:13 pm
+1^
PostSubject: Re: Superlight S13 - No 56K!   Sat May 19, 2012 2:41 pm
An Elise would be great but that's 30K I don't have to throw around. Plus It would be a tight fit for me.
I'm tossing around the idea of an FC, S14, or another superlight with an NA Miata. I still have to get this car in running shape and down to the strip for some runs before I sell it.
Check this out, take a look at some of the builds on here - http://www.norotors.com
PostSubject: Re: Superlight S13 - No 56K!   Sun May 20, 2012 12:01 am
wait ! ur selling it? dude do u ever keep a project? dont get me wrong but why dump money into this to just flip for a fue extra bucks to get into another car ur going to sell anyways! just seems such a waist.
PostSubject: Re: Superlight S13 - No 56K!   Sun May 20, 2012 1:47 am
I've thought about this decision for the past few months, and the choice to sell my baby wasn't easy.
I ran the numbers, and the car's going to need at least 3K worth of parts and lots of labor before it's at the point I'd be ready to race it on the track, which was my original goal.
Since I'm piss poor at selling cars I'm just going to put it up for trade for a stock S14 or 94+ Miata.
PostSubject: Re: Superlight S13 - No 56K!   Sun May 20, 2012 8:54 am
then you will be back to square one with a stock car thats slow that you still need to put 3k or more worth of shit into anyways. s14 is mechanically almost identical to an s13 anyways. whats the point? just my opinion.
PostSubject: Re: Superlight S13 - No 56K!   Sun May 20, 2012 10:18 am
Dude I'm 13 k. Into my wives car and I can't afford do this but I still do I still got another 5 to go but don't mean I'm going to sell to start all over specially. On another 240 that beshpoting ur self in the foot.
PostSubject: Re: Superlight S13 - No 56K!   Sun May 20, 2012 5:52 pm
Shit, don't do this to me guys. You're making me want to keep the car after I made my decision...
If I were to keep the car it needs moar low, and to do that I need coils and new TRE's up front, ball joints in the back, and all new arms and shit for the alignment. That's a good 2K there with Koni/GC and good parts.
My biggest complaint is the fubar'd lights, hood, hood pins, bumper, and fenders.
Ok, tell you what - If kouki chee will sell me his shell and I can swap the core support and front end onto my hatch I'll keep the car around for a while.
PostSubject: Re: Superlight S13 - No 56K!   Mon May 21, 2012 2:30 am
just about any old(ish) car is going to need some work like TRE and ball joints. it just comes with the territory, i wouldn't get to upset about it. just upgrade as you go when you can. if your TRE are bad then get some aftermarket stuff with heims. replace stock garbage as you go.
the s13/s14 is one of the most fun chassis in existence in my opinion. huge aftermarket. light weight (esp. yours) cheap power. just be patient with the suspension parts and in a couple years you will have a kick ass car. may not be the fastest thing ever, or go around corners the best. but you will have something super reliable that gives you a great sense of satisfaction every time you take it out.
i personally own different cars with koni/gc setups and KW coilovers. just save your money and get some variant 2 kw's (or higher) the koni/gc setup is hard to beat for the money. but man KW's are nice.
PostSubject: Re: Superlight S13 - No 56K!   Mon May 21, 2012 8:27 am
I agree tuck thouse pantys and stick it out. U can alwaysssss find shells. Always! Replacing or buying another car with sr in it more problems then its worth.
PostSubject: Re: Superlight S13 - No 56K!   Mon May 21, 2012 12:04 pm
Agreed 100%.
KW's will be my next coilover of choice.
PostSubject: Re: Superlight S13 - No 56K!   Mon May 21, 2012 3:41 pm
I ran across a Cusco SR flywheel online while looking for parts to fix my car and noticed that it looks a lot like the one that came with my engine. I checked the FW out as being magnetic but not looking like the stocker before I dropped the engine in. So I either have a Cusco or Toda 10lb chromoly flywheel - Score!
Also swapped in iridium NGK plugs like Def on NRR mentioned and the car runs much better. I can boost to ~10PSI now with no problems at all, going past 12 has some slight hesitation. So my issue is definitely ignition related as before with new coppers I hit a brick wall at 8PSI.
PostSubject: Re: Superlight S13 - No 56K!   Mon May 21, 2012 3:59 pm
What is your plug gap set to? Maybe you need to close it up a little bit.
PostSubject: Re: Superlight S13 - No 56K!   Mon May 21, 2012 4:21 pm
I had the gap at .025 with the coppers. The iridiums are set from the factory at .030.
I was running 12 PSI with coppers at .035 and pulling nice and strong with no hesitation at all on the stock ECU/injectors before the upgrade.
PostSubject: Re: Superlight S13 - No 56K!   Mon May 21, 2012 4:22 pm
run the plug gap at .025. that is the exact same symptoms i had when i had bad coil packs.
PostSubject: Re: Superlight S13 - No 56K!   Mon May 21, 2012 4:33 pm
You think it's safe to regap the iridiums? The box says adjusting the gap is not advised, and the interwebs says not to touch the gap on iridiums because the ground straps break easily with force.
I've always run coppers in everything else I've owned, so my knowledge in this area is a bit hazy with different parts.
PostSubject: Re: Superlight S13 - No 56K!   Mon May 21, 2012 6:40 pm
yes i would not gap them. sorry about that we posted at the same time and i didn't see your last post before mine. my bad!
my iridium plugs lasted a little over a year. then they started to misfire on me after driving on the hwy for extended periods. i pretty much just put new plugs in every year. always NGK.
PostSubject: Re: Superlight S13 - No 56K!   Thu May 24, 2012 1:09 am
I found that the hose clamp on my IAC hose had slipped off, so I threw on a new one and the car immediately ran better. I set the boost to 12 PSI and the car ran great very briefly.
After I hopped onto the highway it was back to the same old problem, and I found my MBC line popped off this time.
Edit: I ran a boost leak test and the car passes to 20PSI just fine. Still stumbling in boost. Damn.
PostSubject: Re: Superlight S13 - No 56K!   Thu May 31, 2012 1:30 am
I wonder if my FPR isn't causing this. I might just run down to the parts house tomorrow to rent a fuel pressure gauge.
Anybody have an adjustable FPR they want to sell if mine is crap? You know, tsunami water might have killed my regulator. Shocked
PostSubject: Re: Superlight S13 - No 56K!   Thu May 31, 2012 2:52 pm
Did you replace your fuel pump? I thought you did, but I don't feel like cruising back through the thread to see. If you have you should. If you did then you need to install an adjustable FPR. With a upgraded fuel pump and the stock FPR you are going to be running about 50 or so pounds of fuel pressure. Which is about 6.5 psi above stock and can cause you to run rich. If you are still on your stock fuel pump then you are most likely running lean because it will never keep up with a set of 550cc injectors. You really should be running a wideband O2 gauge so you can see what you AFR is doing while your car is having problem, it would aid in your trouble shooting immensly. 2cents
PostSubject: Re: Superlight S13 - No 56K!   Thu May 31, 2012 4:49 pm
I am running a new Walbro 255, Z32 filter, and new rubber fuel lines.
I will order a WB02 when funds allow. I have the car down until then.
PostSubject: Re: Superlight S13 - No 56K!   Thu May 31, 2012 7:50 pm
I'm seeing people complaining about the nismo stock replacement style AFPR being unreliable. That was my first pick - Anybody on here run a Tomei universal type FPR? The only thing I can't find is whether or not it's a 1:1 unit.
http://www.enjukuracing.com/products/TOMEI-Universal-Fuel-Pressure-Regulator-Type%252dS.html
Page 17 of 20Go to page : Previous  1 ... 10 ... 16, 17, 18, 19, 20  Next
