 Air Bubbles in coolant.
PostSubject: Air Bubbles in coolant.   Mon Oct 10, 2011 4:55 pm
Recently I have been having a problem with air bubbles accumulating in my coolant. I can bleed the system and after a few drives I notice the air bubbles are back again. I did a pressure test on the system and it held for over 10 minutes at 30 lbs. of pressure. The cap also tested just fine. I did find one clamp on the lower radiator hose that was a few turns of the wrench loose. I tightened it up and that did not seem to make it go away. I don't think that it is my headgasket because none of the other symptoms of this issue are there. Any ideas on what or where I should be looking at/doing next?
PostSubject: Re: Air Bubbles in coolant.   Mon Oct 10, 2011 4:57 pm
Headgasket.
PostSubject: Re: Air Bubbles in coolant.   Mon Oct 10, 2011 8:08 pm
Thats not what I wanted to hear. No
PostSubject: Re: Air Bubbles in coolant.   Mon Oct 10, 2011 8:19 pm
Ok, turn signal switch.
PostSubject: Re: Air Bubbles in coolant.   Tue Oct 11, 2011 10:21 am
That seems much more logical thank you. Should I check my MAF sensor also?
PostSubject: Re: Air Bubbles in coolant.   Tue Oct 11, 2011 1:01 pm
air from your tires is leaking into your engine. fix it asap.
PostSubject: Re: Air Bubbles in coolant.   Tue Oct 11, 2011 3:13 pm
Did u use the bleeder screw? To get bubbles out
PostSubject: Re: Air Bubbles in coolant.   Tue Oct 11, 2011 7:54 pm
1: Drain the coolant out
2: fill the cooling system with soap and water
3: drive around with the raditator cap off and it will be a bubble machine on wheels
PostSubject: Re: Air Bubbles in coolant.   Wed Oct 12, 2011 3:09 pm
No, I cut the bottom off of 20 oz. soda bottle. then I wrapped electrical tape around the threaded opening until it fit snug in my radiator opening. This way I was able to make a "high point" in the cooling system for the bubbles to travel to. It doesn't matter how muvh I ran the engine and raced it while doing this the bubbles did not go away. Hence blown HG, also I am now noticing tiny little drops of oil in my coolant. Talk about a bitch! Guess I am glad winter is almost here and it is time to park this P.O.S.
PostSubject: Re: Air Bubbles in coolant.   Sat Oct 29, 2011 11:39 am
Also founf droplets of oil in coolant as well. My car is down for the count. Sad
Join the club, BRO!
PostSubject: Re: Air Bubbles in coolant.   Sat Oct 29, 2011 11:42 am
Ohhh so my car caught the Clap from yours then. I guess we can not hang out anymore.
PostSubject: Re: Air Bubbles in coolant.   Sat Oct 29, 2011 11:45 am
No... we just need to use protection the next time your car goes into heat. lol!
