 need to clean(realllllyyy good and prep) the aluminum from the block .....
PostSubject: need to clean(realllllyyy good and prep) the aluminum from the block .....   Mon Oct 24, 2011 4:23 pm
im painting the front cover and valve cover for the ka24de but id like to hot tank and smooth the lumps. anyone know local shop that would do that or even how i can search for one. what would i look under?
PostSubject: Re: need to clean(realllllyyy good and prep) the aluminum from the block .....   Mon Oct 24, 2011 4:27 pm
Most machine shops have that capability.
PostSubject: Re: need to clean(realllllyyy good and prep) the aluminum from the block .....   Mon Oct 24, 2011 4:48 pm
any idea what they may charge just as a guess on what to spend.
PostSubject: Re: need to clean(realllllyyy good and prep) the aluminum from the block .....   Mon Oct 24, 2011 4:50 pm
I have no idea, but it should be fairly cheap... like $50 if I had to guess.
PostSubject: Re: need to clean(realllllyyy good and prep) the aluminum from the block .....   Mon Oct 24, 2011 4:53 pm
wow sweeeeet thank jim as always your my mechanicl angel banana
PostSubject: Re: need to clean(realllllyyy good and prep) the aluminum from the block .....   Mon Oct 24, 2011 4:56 pm
^ that was just a guess now. Don't take it as gospel.
PostSubject: Re: need to clean(realllllyyy good and prep) the aluminum from the block .....   Mon Oct 24, 2011 4:59 pm
rofl2 no man come on i know , buy the way u know anyone that can spray metal flake pink?
PostSubject: Re: need to clean(realllllyyy good and prep) the aluminum from the block .....   Mon Oct 24, 2011 5:00 pm
Chuck????? rofl
and also hot tank or sand blast?
PostSubject: Re: need to clean(realllllyyy good and prep) the aluminum from the block .....   Mon Oct 24, 2011 5:01 pm
whos chuck , i dont do truckers. lol
PostSubject: Re: need to clean(realllllyyy good and prep) the aluminum from the block .....   Mon Oct 24, 2011 5:02 pm
media blasting might smooth them out a little more... that'll probably cost more though.
And it's Chuck the Chizzle.
PostSubject: Re: need to clean(realllllyyy good and prep) the aluminum from the block .....   Mon Oct 24, 2011 5:06 pm
ahh chuky! otay
PostSubject: Re: need to clean(realllllyyy good and prep) the aluminum from the block .....   Mon Oct 24, 2011 5:08 pm
^ I was kinda joking. I don't know if he can spray it, but he sure likes it! Embarassed
PostSubject: Re: need to clean(realllllyyy good and prep) the aluminum from the block .....   Mon Oct 24, 2011 5:45 pm
there is a place in Buler (U-Spray) that allows you to sand/media blast what ever you bring to them as long as it is clean. I would call up C&S performance in Butler or other machine shops (Borchardts,Kilpatricks) and see if they offer a hot tank / acid dip.
PostSubject: Re: need to clean(realllllyyy good and prep) the aluminum from the block .....   Fri Nov 04, 2011 5:51 pm
i got a soda blaster and did it myself alredy paint just need to do the main cover and imn done .
Wisconsin240sx :: General Chat-
