 head gasket?
airman240
PostSubject: head gasket?   Tue Nov 15, 2011 4:56 pm
Hey got another question, Im running the precision 6152e on my sr20det, Im just wonderin if anyone has any recommendations for head gasket for lower compression? Im going to put in 1000cc injectors, so im just trying to figure out what would be best for the motor before i need to rebuild it.
PostSubject: Re: head gasket?   Tue Nov 15, 2011 5:35 pm
One of the turbo gurus will chime in, I'm sure.
PostSubject: Re: head gasket?   Tue Nov 15, 2011 5:58 pm
what gasket is in the car as of right now? i would think you should be ok, depending on power/tune.
PostSubject: Re: head gasket?   Tue Nov 15, 2011 6:04 pm
we have turbo guru's??
PostSubject: Re: head gasket?   Tue Nov 15, 2011 7:08 pm
most people seem to run the apexi or cosworth stuff. my car is running the stock gasket without any issues.
PostSubject: Re: head gasket?   Tue Nov 15, 2011 8:12 pm
I ran the apexi 1.1 with my gt2871 and 750cc. It also depends on if your block has been decked off and or head surfaced.
airman240
PostSubject: Re: head gasket?   Wed Nov 16, 2011 3:27 pm
Right now the head/gasket is all sr20det stock. I heard the motor can take like 400hp ish so that's why I'm asking around and trying to get some heads up on it before i start workin on it. Thanks for any help tho
PostSubject: Re: head gasket?   Wed Nov 16, 2011 6:53 pm
Whats your hp goal?
PostSubject: Re: head gasket?   Wed Nov 16, 2011 9:22 pm
3,000 hp
PostSubject: Re: head gasket?   Wed Nov 16, 2011 9:38 pm
been running mine over 300 hp for 6 years now on stock everything...400 is easy as long as your tune is good.
airman240
PostSubject: Re: head gasket?   Thu Nov 17, 2011 4:42 pm
Don't really know exactly what my hp goal is, biggest i can reach with stock motor for now i supposed. Just doing the turbo swap over winter so im trying to figure stuff out. But thanks for the info guys, im gna do a slight tun with my afc but hopefully get it to a shop for a professional tune sooner or later after everythings working.
head gasket?
