 how to install radiator s13/s14
PostSubject: how to install radiator s13/s14   Tue Sep 14, 2010 3:53 pm
step1. park your car on a flat surface and put something behind your rear tires to keep it from rolling back on you..."dont forget to raise your ebrake"
step2. jack the front end with a jack and stands so you can get underneath it..
step3. find the drain screw and put a bucket under it... "should be on driver side"
step4. drain the coolant from the radiator...
step5. unhook radiator hoses... "just the end that connects to the radiator unless your gonna replace them... its easier to remove the bottom one from underneath the car"
step6. Unbolt upper radiator screws and keep track of the rubber grommets that go on the arms... "you still need them for your new radiator"
step7. remove what ever you have in front of the radiator to make it easier to pull out the radiator... "fan shroud/intake"
step8. remove radiator fan and lower fan shroud...
step9. pull the radiator out and be sure to pull the rubber grommets off the bottom of the old radiator to put them on the new one too...
step10. install new radiator in reverse order....
step11. add coolant until its full... "u can squeeze the upper radiator hose to pump some coolant into the engine"
step12. with the front of the car still jacked up start the car and add coolant through the rad cap hole as the bubbles work their way out of the system... be sure your heater is on full.... this should bleed the air out.... there is also a bleeder screw where the upper radiator hose connect to the engine...
step13. install rad cap and add coolant to the 1/4 mark in the overflow and go for a test drive...
NOTE: MAKE SURE ALL THE HOSES AND THE DRAIN SCREW ARE TIGHT... IF CAR OVER HEATS, BLEED IT AGAIN... IF RADIATOR SMOKES, TAKE A GARDEN HOSES AND SPRAY THE RADIATOR TO GET ALL OF THE COOLANT OFF SO IT DOESN'T BURN AND SMOKE...
PostSubject: Re: how to install radiator s13/s14   Tue Sep 14, 2010 7:20 pm
Nice write up, all u need are some pics.. If I took any when we did mine I woulda added them lol
PostSubject: Re: how to install radiator s13/s14   Wed Sep 15, 2010 11:44 am
ill take some pictures but im not gonna pull my rad out again though...lol
PostSubject: Re: how to install radiator s13/s14   Wed Sep 15, 2010 6:42 pm
Ha can I do a write up on how to/where to use zip ties? Lmao
PostSubject: Re: how to install radiator s13/s14   Wed Sep 15, 2010 7:04 pm
great!!!!!!! i need that because i lost tons of screws
PostSubject: Re: how to install radiator s13/s14   Wed Sep 15, 2010 7:20 pm
I know your pain haha, id say I got maybeeee
Well atleast 15 zip ties haha... on my car lol
PostSubject: Re: how to install radiator s13/s14   Wed Sep 15, 2010 9:20 pm
i know i got 4 for sure holding the bumper to the fender...lol
PostSubject: Re: how to install radiator s13/s14   Wed Sep 15, 2010 10:28 pm
i have a ton, but alot are keeping wires tied up and out of places... thankfully none are holding my car together haha.
even though i do love zipties... i have a shirt to prove it.
and if for some reason we gotta take my rad out this winter, ill snap some shots too.
PostSubject: Re: how to install radiator s13/s14   Wed Sep 15, 2010 10:31 pm
yeah... my wires in my engine bay is crazy!!!!!... wire tuck hopefully coming soon
PostSubject: Re: how to install radiator s13/s14   Wed Sep 15, 2010 10:35 pm
oo thatll be nice!
PostSubject: Re: how to install radiator s13/s14   Wed Sep 15, 2010 10:47 pm
you should check out Chasebays stuff for wire tucking!
PostSubject: Re: how to install radiator s13/s14   Thu Sep 16, 2010 11:30 am
yeah hopefully it'll look clean after i respray my engine bay chromish silver...
i dont want to buy another radiator... just bought a isis radiator about 2months ago
