 my quest for 800 whp
Go to page : 1, 2, 3, 4  Next
jrp355
PostSubject: my quest for 800 whp   Sun Nov 27, 2011 8:56 pm
alright well im new to the game and have no experience with the sr20det motor what so ever. I know the sr20 motor is a closed deck ( ports for coolant) motor unlike the honda motors that are open deck (coolant flows around cylinder sleeves and the block itself.
now i am sorta on a budget for a engine for relatively cheap and am most likely going to build it. i would like to know how much power can be made on stock sleeves. i of course am going to go with after market pitstons and rods.
also i was wondering what rod bearings have prooven to be very pullet proof.
thanks
PostSubject: Re: my quest for 800 whp   Sun Nov 27, 2011 10:57 pm
no reason to do a SR20 at that point what soever at all.
it will need to be FULLY built (head/cams/rods/pistons maybe even a stroker kit) not to mention the fuel/clutch/ 65+mm turbo etc. to run anywhere near that.
I would say go with a 2JZGTE with headworks/cams and a decent single turbo on e85 you could do it. or do a LSX motor with a 76mm and the car will make that no problem. no reason to start with one of the smallest motors to do it.
jrp355
PostSubject: Re: my quest for 800 whp   Sun Nov 27, 2011 11:04 pm
arent the 2jz motors super expensive to swap in. and by the time the shell is molested to hell to put the motor in ill pry be 10k in the hole and a bone stock 2jz
PostSubject: Re: my quest for 800 whp   Sun Nov 27, 2011 11:40 pm
you aren't going to get 800whp for 10k. not while buying a car and building it from scratch.
cheap
reliable
fast
pick two^
PostSubject: Re: my quest for 800 whp   Sun Nov 27, 2011 11:44 pm
not in a car that will ever stop, turn, be comfortable, safe or reliable i should add.
jrp355
PostSubject: Re: my quest for 800 whp   Mon Nov 28, 2011 12:06 am
wow....haters already. yeah my 800 goal is high, but im not asking your opinion on whether i should try and get 800whp, im asking whether i need to sleeve the block in order to achieve this goal. if so i am going to go another route. Im new to this site, but i am not new to what 4 cylinders can do power wise. there are hondas out there making 1000hp (outlaw fwd). This isnt a 4 week build. i have however long it takes to get it where i want it and if i go over budget o well. so if you could help me out i would appreciate it.
just cause i dont wanna buy your stock sr20 with bolt ons for 10,000. dont come on here bashing on my goals
jrp355
PostSubject: Re: my quest for 800 whp   Mon Nov 28, 2011 12:08 am
cheap
reliable
fast
pick two^
i pick fast and reliable bob haha....
PostSubject: Re: my quest for 800 whp   Mon Nov 28, 2011 7:40 am
nevermind...
PostSubject: Re: my quest for 800 whp   Mon Nov 28, 2011 10:44 am
actually that is where you are wrong. you can get a JDM 2JZGTE for about $2000 shipped, which is about the same price as a SR20DET is now a days. Mount kit/wiring/drift shaft is about $800-1000. Single turbo kit setup 3k. E85 fuel system 2k. etc etc.
[You must be registered and logged in to see this link.] check that guy's car out. that WAS a 700WHP SR. he has since downtuned it in to the 500 do to this thing called powerband, or lack there of.
I know of many 500+WHP Honda's out there. honestly the B16/B18/K20 has alot more full blown drag support then the SR20/CA18/Etc. has. do to the fact the 240sx is a RWD car and you can put pretty much ANY motor in it. Maybe you should build a B18 powered 240sx. or Keep in the Honda scene. cause there aren't very many 700+ HP SR20's cause anyone who has that much cash and wants a car THAT fast, does a Turbo V8 or a 2JZ / RB2X
PostSubject: Re: my quest for 800 whp   Mon Nov 28, 2011 11:58 am
haha^ i wrote a big post similar to that but i figured you would complain about me ripping this kid a new one. so i just took the high road.
wack it
well done flick.
PostSubject: Re: my quest for 800 whp   Mon Nov 28, 2011 12:37 pm
Wasn't the issue with the older Honda engines that they spun the wrong way?
Everyone knows the RB26 is the coolest engine. pirat
If I redid it, and was able to fool myself that building an over powered car was worth doing, I'd build a 1JZ RS13.
jrp355
PostSubject: Re: my quest for 800 whp   Mon Nov 28, 2011 12:55 pm
If its so easy to do this why do I see numerous people talking about pushing in their firewall, using the GTE subframe, if its as easy as your saying please point me in the right direction to find a wiring harness and other parts to make this a plug and play setup
PostSubject: Re: my quest for 800 whp   Mon Nov 28, 2011 12:56 pm
gforce sells a reverse rotation dog box.. you could use that
there is a full how to 2jz thread on this forum. look
PostSubject: Re: my quest for 800 whp   Mon Nov 28, 2011 1:01 pm
More than likely you will have to resleeve the motor if you get to that HP level. If you want a 4 banger that can produce that much power reliably would be a ecotec, zetec or the duratec. With the ecotec Chevy even has a guide to build the motor to the HP you want. I am not bashing your hopes to get an Sr to that level of power just putting my .02 in
PostSubject: Re: my quest for 800 whp   Mon Nov 28, 2011 1:04 pm
i made a huge 2JZGTE swap thread on here in the tech section.
there are a ton of swap kits from $200-$1500. that dont require ANY hammers to fit,unlike LSX/RB swaps.
you too said you're new. we aren't being rude, just take advice from people who know it. thats like me going on honda-tech and saying i want to build a D16Vtec to 800whp. people are going to give me better suggestions,because they have been through it.
PostSubject: Re: my quest for 800 whp   Mon Nov 28, 2011 1:37 pm
even though you are being a total douche ill send you in the right direction.
call mazworx. they can tell you anything you want to know. (sr wise)
PostSubject: Re: my quest for 800 whp   Mon Nov 28, 2011 2:03 pm
The hammering was minimal on my swap... I've done more punishment on single moms than I did on my firewall.
PostSubject: Re: my quest for 800 whp   Mon Nov 28, 2011 3:44 pm
omfgggggggg ^^^^^ i almost pissedddd myself when i read this
and fyi we aren't haters, you came on here asking a question
dont hate on US when we give you a bigger answer than what you wanted...
you could have just googled your damn question
and douche would be the correct word....
PostSubject: Re: my quest for 800 whp   Mon Nov 28, 2011 4:47 pm
lol i like how he has 10 posts and -7 reputation.
PostSubject: Re: my quest for 800 whp   Mon Nov 28, 2011 5:05 pm
yea haha hes more hated than that driftx doucher from IL haha
PostSubject: Re: my quest for 800 whp   Mon Nov 28, 2011 6:38 pm
Don't hate. That's technically why we're here, isn't it? To answer questions...
It won't take long to realize this goal is ridiculous for an sr.
PostSubject: Re: my quest for 800 whp   Mon Nov 28, 2011 6:42 pm
my hp range for my ca18 is 900
YOU'LL GET IT!
PostSubject: Re: my quest for 800 whp   Mon Nov 28, 2011 7:03 pm
wow i need to stop by more often lol this is fun, and new kid,guy m dude whatever u are! there is no, let me repeat NOOOO! sr motor making 800hp that runs longer then 200 miles without a rebuild! the more power AT THE CRANK THE MORE VIBRATION DAMAGE THERE WILL BE and i see u want to beat it , ur prone to grenade a fresh build . as much as i dont want to say it a 2jz is the SMART WAY TO GO. BULLIT PROOF MOTOR TOP QUALITY PARTS AND HANDS DOWN RELIABLE!
COST VS PERFORMANCE , ITS DAME WELL WORTH IT!
Page 1 of 4Go to page : 1, 2, 3, 4  Next
