 coolant reserve
JasonAldana
PostSubject: coolant reserve   Thu Dec 22, 2011 3:38 pm
so ive got a leak in my coolant reservoir, so currently my heat sucks. lol im not sure where its leaking from yet but ive looked up for a new one. and its much too expensive for a plastic bottle. are there any ways to fix my current one. or would i be better off buying a new one.?
PostSubject: Re: coolant reserve   Thu Dec 22, 2011 4:04 pm
better off buying a new one. You might be able to come up with something "creative" or look at junkyards/ebay for a coolant overlow tank/ reservoir and switch it out.
PostSubject: Re: coolant reserve   Thu Dec 22, 2011 4:19 pm
New one is easiest, but waterproof JB is a cheap fix. You will have to clean it first though, as antifreeze is a good slippery lube. Razz
PostSubject: Re: coolant reserve   Thu Dec 22, 2011 4:43 pm
find some random ass one that fits if you are to cheap for a new one. its not like it has to be exact. most cars have very similar bottles.
PostSubject: Re: coolant reserve   Thu Dec 22, 2011 4:45 pm
Also, looking at the original post, a reservoir leak will not cause a no heat issue. You sir, have another problem.
PostSubject: Re: coolant reserve   Thu Dec 22, 2011 4:47 pm
if you run out of coolant that doesn't help your heat much. but yeah you shouldn't be losing that much out of there.
PostSubject: Re: coolant reserve   Thu Dec 22, 2011 4:49 pm
You will only lose the expansion amount from heat. Old cars didn't have overflow bottles, it just spilled on the ground. You can thank hippies for the reservoirs.
PostSubject: Re: coolant reserve   Thu Dec 22, 2011 6:48 pm
true. sill losing coolant though.
PostSubject: Re: coolant reserve   Thu Dec 22, 2011 6:54 pm
Only to a certain point... It will get to a point where it won't overflow anymore.
PostSubject: Re: coolant reserve   Thu Dec 22, 2011 7:18 pm
at that point air pockets could block flow to the heater core. happened to a few cars I've worked on before
PostSubject: Re: coolant reserve   Fri Dec 23, 2011 3:43 pm
Do you smell coolant in the cabin area? Leaking heater core maybe?
coolant reserve
