 Help Needed....S14 Wanting To Convert To 300ZX Brakes
BoostAddct
PostSubject: Help Needed....S14 Wanting To Convert To 300ZX Brakes   Sun Jan 22, 2012 5:35 pm
I've got a friend that's looking to upgrade to 300ZX Calipers/Rotors and 5 Lug Hubs on his S14...He already bought the 5 Conversion Hubs to bolt into his stock spindles and he just purchased 300ZX TT Front Rotors....now he needs to get the 300ZX TT Front calipers and I told him that he would probably need the caliper brackets as well, but he wasn't sure. Does anyone on here know if he will need the brackets and if they will bolt to his stock spindles? Also are there any other parts he will need?
Also....does anyone around here do caliper rebuilds? I was thinking it may be best for him to buy junkyard calipers and then before he gets them rebuilt he can have them powdered.
Thanks for the help guys!
PostSubject: Re: Help Needed....S14 Wanting To Convert To 300ZX Brakes   Sun Jan 22, 2012 5:38 pm
I believe they sell swap brackets for those callers on S14s, I'm sure someone with them will chime in.
As far as rebuilding them, there's nothing to it. Don't be scared.
BoostAddct
PostSubject: Re: Help Needed....S14 Wanting To Convert To 300ZX Brakes   Sun Jan 22, 2012 5:46 pm
I guess I've never looked into it, but I can't imagine it being hard at all....The seals probably aren't too expensive from the dealer I'd assume...
PostSubject: Re: Help Needed....S14 Wanting To Convert To 300ZX Brakes   Sun Jan 22, 2012 5:48 pm
You should be able to find aftermarket kits for rebuilding too... might be cheaper.
KyleMich
PostSubject: Re: Help Needed....S14 Wanting To Convert To 300ZX Brakes   Sun Jan 22, 2012 9:28 pm
Overall Z32 Brake upgrade info: [You must be registered and logged in to see this link.]
Caliper Rebuild: [You must be registered and logged in to see this link.]
Hope this helps! Very Happy
BoostAddct
PostSubject: Re: Help Needed....S14 Wanting To Convert To 300ZX Brakes   Mon Jan 23, 2012 8:57 am
Thanks Kyle! Those help a ton!
KyleMich
PostSubject: Re: Help Needed....S14 Wanting To Convert To 300ZX Brakes   Mon Jan 23, 2012 9:03 am
No problem
PostSubject: Re: Help Needed....S14 Wanting To Convert To 300ZX Brakes   Mon Jan 23, 2012 3:08 pm
the sticky posts in here are there for a reason.
there are several brake related links in there.
