 Fuel pump.
Go to page : Previous  1, 2, 3, 4, 5  Next
PostSubject: Re: Fuel pump.   Mon Feb 06, 2012 4:41 pm
Not true that its the only fuel related part you havent changed. The wiring on all s13s for the fuel pump is very inadequate and as the car gets older, the continuity in the wires gets worse. The insulation cracks and now when you make corners it touches the chassis and grounds out. BAM!!! no fuel pump/shorted life span of fuel pump. Start tracing wires before you buy a new pump. Then DMM the wire for continuity through them. If it all checks out great then buy a pump and see if it helps.
PostSubject: Re: Fuel pump.   Mon Feb 06, 2012 4:44 pm
93sapphirecoupe wrote:
they aren't made to run continuously like that. get a temp controlled fan controller for 100 bucks.
+1
Please do it the right way, and not be another dipshit hack.
PostSubject: Re: Fuel pump.   Mon Feb 06, 2012 4:45 pm
after fighting with DIF for 6 months i finally got my controller to work pjmonkey they were helpful but I'm not sure i would ever buy another one from them.
Nizmo Newbie
PostSubject: Re: Fuel pump.   Mon Feb 06, 2012 4:52 pm
It was my fuel pump, the wires were new so I just got a wallbro and wired it in and its been good.
PostSubject: Re: Fuel pump.   Mon Feb 06, 2012 4:53 pm
banana
PostSubject: Re: Fuel pump.   Mon Feb 06, 2012 6:14 pm
Nizmo Newbie wrote:
I found my problem with dying and turning right, it was my power steering system. Thanks
riaa
ghey fight
Nizmo Newbie
PostSubject: Re: Fuel pump.   Tue Feb 07, 2012 11:26 am
I feel dumb i took my power steering out and i got the altima fans to replace the clutch fan but ive been reading and it didnt accur to me that the water pump is ran off of the same belt. So my questian is if there is a belt small enough that will run just the clutch fan and water pump. Ive herd of a rx7 belt off of a 91 but im not sure. Thanks
PostSubject: Re: Fuel pump.   Tue Feb 07, 2012 11:48 am
belts are sold in mm measurements. take a string and a mm tape measure and figure out what you need.
Nizmo Newbie
PostSubject: Re: Fuel pump.   Tue Feb 07, 2012 12:27 pm
Is this the normal way to do this. Just having a belt on the clutch fan and bottom pulley? I dont want to cause more problems then need be.
PostSubject: Re: Fuel pump.   Tue Feb 07, 2012 12:59 pm
You need something to tension the belt. Vato Zone sells idler pulleys that bolt in place of accessories, I think.
Nizmo Newbie
PostSubject: Re: Fuel pump.   Tue Feb 07, 2012 1:07 pm
Well ive found that people leave the pump and just take the componets out and fill them with fluid. So its basically just a tensioner.
PostSubject: Re: Fuel pump.   Tue Feb 07, 2012 1:43 pm
on one of my cars i have a straight belt with no tensioner running the water pump. straight from the crank pulley. never had any issues, ever. you just have to make sure its somewhat of a tight fit. then put it on like a bike chain. just sayin.
or you could put your power steering back on like a normal person.
Nizmo Newbie
PostSubject: Re: Fuel pump.   Tue Feb 07, 2012 1:53 pm
My pumps out and I dont want to biy another or worry about it going out again. So I just want it off. Ill try what you have or just use the water pump as a tensioner.
PostSubject: Re: Fuel pump.   Tue Feb 07, 2012 2:26 pm
you have the single slammer or dohc ka?
Nizmo Newbie
PostSubject: Re: Fuel pump.   Tue Feb 07, 2012 2:28 pm
I have the dohc. I would go to the junk yard and do the sohc alternator bracket set up but the junkyards around here are pretty scarce.
PostSubject: Re: Fuel pump.   Tue Feb 07, 2012 2:40 pm
I got that setup for 40 bucks if you want to come get it.
I was without power steering for a few years on my car and it was stupid and annoying. Especially at the track drifting without it I felt like I was going to pop my shoulder out of its socket.
Nizmo Newbie
PostSubject: Re: Fuel pump.   Tue Feb 07, 2012 2:43 pm
I dont do anything trafic related so Im nust taking it out. I like the extra room in the motor bay aswell lol. Are you close to kenosha?
PostSubject: Re: Fuel pump.   Tue Feb 07, 2012 3:22 pm
I'm in Delavan. Like an hour from Kenosha.
PostSubject: Re: Fuel pump.   Tue Feb 07, 2012 3:33 pm
Suspect
PostSubject: Re: Fuel pump.   Tue Feb 07, 2012 4:11 pm
He's young, let him figure it out.
Nizmo Newbie
PostSubject: Re: Fuel pump.   Tue Feb 07, 2012 4:14 pm
Ive had many cars without power steering. It doesnt bother me all that much.
PostSubject: Re: Fuel pump.   Tue Feb 07, 2012 4:16 pm
^ Like I said, you're young. Sooner or later you'll get it.
PostSubject: Re: Fuel pump.   Tue Feb 07, 2012 4:36 pm
There is a reason that they don't make cars without power steering anymore. 2cents
PostSubject: Re: Fuel pump.   Tue Feb 07, 2012 7:56 pm
probably not many with 7+ degrees of caster....
you will figure it out though. like 600 said
PostSubject: Re: Fuel pump.   Tue Feb 07, 2012 8:48 pm
is this real life?
Fuel pump.
Page 3 of 5Go to page : Previous  1, 2, 3, 4, 5  Next
