 A few SR questions.
Go to page : Previous  1, 2, 3  Next
PostSubject: Re: A few SR questions.    Tue Feb 07, 2012 8:46 pm
6 Lbs. with part of the High pressure line attached to it( this was on my SR when it was shipped to me, it is the same as the KA pump though).
PostSubject: Re: A few SR questions.    Wed Feb 08, 2012 6:48 am
Do that, I'm kind of interested now.
SicktwinturboZ
PostSubject: Re: A few SR questions.    Wed Feb 08, 2012 10:35 am
I have a backup brand new p/s rack for ya!!! And a blue greddy pulley!!! Ehhh ehhh!!???
PostSubject: Re: A few SR questions.    Wed Feb 08, 2012 10:37 am
how much for the rack?
SicktwinturboZ
PostSubject: Re: A few SR questions.    Wed Feb 08, 2012 10:44 am
Unless my info is really off it's looking like they are about 250 new. So like 150?? I did the same thing, depowered the power rack and had that for a back up but it worked like a charm. It's easier to turn now than with power assist.
PostSubject: Re: A few SR questions.    Wed Feb 08, 2012 10:46 am
cool. maybe ill get that in a couple months if you still have it. need some other stuff first.
SicktwinturboZ
PostSubject: Re: A few SR questions.    Wed Feb 08, 2012 10:53 am
I don't think it's going anywhere anytime soon!!
PostSubject: Re: A few SR questions.    Thu Feb 09, 2012 4:38 pm
I ordered an S13 blacktop along with some exhaust parts and a cheap non BOV style intercooler.
Thanks for the help guys!
PostSubject: Re: A few SR questions.    Thu Feb 09, 2012 4:47 pm
Who did you order the engine from? GL with the swap! cheers
PostSubject: Re: A few SR questions.    Thu Feb 09, 2012 4:56 pm
Nagano, out of VA. They had plenty of great feedback and the pullout looks to be in good shape. Also ordered an SS elbow, SS down pipe, SS clutch line, and some other little things.
Linky - [You must be registered and logged in to see this link.]
Next big purchase is going to be a Koni/GC setup. 2K lb curb weight is looking very doable.
PostSubject: Re: A few SR questions.    Thu Feb 09, 2012 5:13 pm
looks like aftermarket motor mounts on there.
PostSubject: Re: A few SR questions.    Thu Feb 09, 2012 5:14 pm
I noticed that right away. Everything else appears stock.
PostSubject: Re: A few SR questions.    Thu Feb 09, 2012 5:38 pm
yeah...those are cusco or kazama mounts....good score on that part
PostSubject: Re: A few SR questions.    Thu Feb 09, 2012 5:49 pm
I'm disappointed with Nissan - Installing cast iron brackets on an otherwise all aluminum block. Cutting costs, but still...
I was intending to make some sort of CF alternator bracket for my 5.3 LS, so we'll see what I end up doing on the SR. A heim joint style adjuster/mount looks possible.
Cast iron isn't sticking around on the car if I can help it though.
PostSubject: Re: A few SR questions.    Thu Feb 09, 2012 6:54 pm
Looks like a nice engine. It is missing the factory boost solenoid. Not a big deal if you are going to run a aftermarket. otherwise you are limited to 7lbs the wastegate is set at. The mounts look like a good score. Maybe you will end up with a nice clutch and flywheel also.
PostSubject: Re: A few SR questions.    Thu Feb 09, 2012 7:12 pm
How does this solenoid affect the turbo's overall operation?
Sounds similar to an ECU regulated boost controller off hand.
PostSubject: Re: A few SR questions.    Thu Feb 09, 2012 7:29 pm
It is basically a boost controller. It allows the turbo to hit 11lbs which is the stock amount from the factory compared to 7lbs that everyone claims because they do not have this part. What is wierd is that it is on the same bracket as the ignitor chip and fo whatever reason someone removed it from yours. Probably the car it was in had a aftermarket controller so they removed the factory one. Not a big deal though.
PostSubject: Re: A few SR questions.    Thu Feb 09, 2012 7:36 pm
Judging by a quick search this isn't kept on most swaps. So a standard MBC in between the WG signal and the vacuum source should work fine, right?
PostSubject: Re: A few SR questions.    Thu Feb 09, 2012 8:01 pm
Yeah, it will work just fine. It is just odd that most swaps don't get this part. The stock turbo is pretty much maxed out at 12-13lbs. any way. So if you want more boost a bigger turbo would be needed and then you would install some sort of boost control device at that point anyway.
PostSubject: Re: A few SR questions.    Thu Feb 09, 2012 8:14 pm
I am considering the much loved GT2871 as a future option. My priority is weight reduction and driver training over more power though.
Also ordered a tubular exhaust manifold and new O.E gaskets. Thinking about having the manifold coated locally as well. Would look nice in semi gloss black with a heat shield mounted for a more stock appearance.
PostSubject: Re: A few SR questions.    Thu Feb 09, 2012 10:42 pm
don't cheap out on a manifold....you'll thank yourself later.
PostSubject: Re: A few SR questions.    Fri Feb 10, 2012 1:03 am
I like this thread.
In to see the home-fabbed weight weenie mods that I'd like to do on my own project once the primary "running" goal is achieved.
PostSubject: Re: A few SR questions.    Fri Feb 10, 2012 1:44 am
You mean when I drop in the LS3?
Kidding, that'll come much later. Laughing
77, keep your eyes peeled. I have rolls of CF and resin at my disposal and I am very creative. Although not particularly quick with the pictures.
My idea to do away with the cast iron alternator mount and replace it with a threaded heim joint. This is on a boosted LS1 - Same idea.
PostSubject: Re: A few SR questions.    Fri Feb 10, 2012 1:48 am
Haha, no problem. Razz
PostSubject: Re: A few SR questions.    Fri Feb 10, 2012 2:15 am
make us cf parts! recoup some build costs while hooking fellow owners up. i wouldn't mind a carbon coilpack cover or b-pillar trim. maybe a carbon panel to replace sunroof glass but retain the function of it. i wouldn't mind a panel for my dash for gauges
A few SR questions.
Page 2 of 3Go to page : Previous  1, 2, 3  Next
