 The Unicorn.... The tale of a neverending project....now with more 5 lug.
Go to page : Previous  1, 2, 3, 4  Next
PostSubject: Re: The Unicorn.... The tale of a neverending project....now with more 5 lug.   Tue Feb 14, 2012 9:56 pm
Thats cool everything important like an oil pan i plane it smooth so i can guarantee the seal.
If your going with that pan you may want to look into the n2 oil block as well. Cheap easy way to get more oil into the system, run a cooler and oil filter relocation. Without having the worry of a screw on version coming off. Im running one and the quality is 2nd to none. Only thing i did was re-tap one of the 1/8"pt oil senor holes to use my autometer sending unit.
PostSubject: Re: The Unicorn.... The tale of a neverending project....now with more 5 lug.   Tue Feb 14, 2012 10:13 pm
would a sr oilpan fit a ka??
PostSubject: Re: The Unicorn.... The tale of a neverending project....now with more 5 lug.   Tue Feb 14, 2012 11:47 pm
I have a trust/greddy oil filter relocation kit already and that comes with the screw on adapter that is a quality piece. once i do boost up and turbo upgrade i will worry about a cooler. stock setup i am not gonna worry about it.... right now it looks like i am gonna go with the moroso. found a deal on one that is hard to pass up.
PostSubject: Re: The Unicorn.... The tale of a neverending project....now with more 5 lug.   Tue Feb 14, 2012 11:49 pm
if you're good at welding, sure.
PostSubject: Re: The Unicorn.... The tale of a neverending project....now with more 5 lug.   Tue Feb 14, 2012 11:52 pm
i suck ass at welding , why do i fucking suck ass so bad Mad
PostSubject: Re: The Unicorn.... The tale of a neverending project....now with more 5 lug.   Wed Feb 15, 2012 10:34 am
Tony an sr oil pan will fit a ka all day long if you buy the xccesive upper oil pan adaptor. Then all you do is bolt the sr pan to it.
look here for what ive been telling you:
http://www.xcessivemanufacturing.com/ONLINESTORE.html?cid=41&step=4&pid=145
PostSubject: Re: The Unicorn.... The tale of a neverending project....now with more 5 lug.   Wed Feb 15, 2012 11:37 am
yea but thats a 700$ oil pan man ! fuck that. 400 for the base 400 for the pan. im good!
PostSubject: Re: The Unicorn.... The tale of a neverending project....now with more 5 lug.   Wed Feb 15, 2012 2:33 pm
i hear ya. But it is a very nice piece that will make it so your not welding to stock sheet metal. Plus its basically a built in windage tray. And you can still run a high capacity oil pan. Big plus for any nissan motor
PostSubject: Re: The Unicorn.... The tale of a neverending project....now with more 5 lug.   Wed Feb 15, 2012 3:04 pm
tomei is on the way. if you know any one looking for a moroso tho check out TF's clearence section. they have a demo one they lost the box for.
PostSubject: Re: The Unicorn.... The tale of a neverending project....now with more 5 lug.   Wed Feb 15, 2012 8:24 pm
Nice choice.
PostSubject: Re: The Unicorn.... The tale of a neverending project....now with more 5 lug.   Wed Feb 15, 2012 8:46 pm
yeah...it was either that or an ebay greddy knockoff. decided to get the tomei because it has a shorter name...easier to remember since i am getting old. plus if you pronounce it wrong it rhymes with "on the way"
PostSubject: Re: The Unicorn.... The tale of a neverending project....now with more 5 lug.   Tue Feb 21, 2012 11:59 pm
had to go out to the shop today for a few things....while waiting for some one i decided to tape my wing on there and set my bumper behind my car.
it's not for everyone.... but if you could all be dears and go like my pic, i'd appreciate it, pee pee touches for all
http://www.facebook.com/photo.php?fbid=10150579803573026&set=o.116666305064313&type=1&ref=nf
PostSubject: Re: The Unicorn.... The tale of a neverending project....now with more 5 lug.   Wed Feb 22, 2012 12:09 am
Removed.
PostSubject: Re: The Unicorn.... The tale of a neverending project....now with more 5 lug.   Wed Feb 22, 2012 1:45 am
it's hard to explain but most of my mods are turning out to be shit that nobody liked from 99-02. pink paint, wangan wing, sileighty, etc. in the end, it will work out and you will love it or hate it. there won't be much middleground.
PostSubject: Re: The Unicorn.... The tale of a neverending project....now with more 5 lug.   Wed Feb 22, 2012 1:47 am
Removed.
PostSubject: Re: The Unicorn.... The tale of a neverending project....now with more 5 lug.   Wed Feb 22, 2012 1:51 am
basically. i <3 yashio factory.
PostSubject: Re: The Unicorn.... The tale of a neverending project....now with more 5 lug.   Wed Feb 22, 2012 10:30 am
dem good days.
PostSubject: Re: The Unicorn.... The tale of a neverending project....now with more 5 lug.   Wed Feb 22, 2012 3:53 pm
love that wing.
PostSubject: Re: The Unicorn.... The tale of a neverending project....now with more 5 lug.   Wed Feb 22, 2012 4:41 pm
if this is ur final produ. im all in man ur cars going to br tittys! im jelly man wish i had the resource to do it, but ur on point chuck fuck the haters its hot!! 3 dicks up for pink!
PostSubject: Re: The Unicorn.... The tale of a neverending project....now with more 5 lug.   Mon Mar 05, 2012 2:27 pm
so at like 9:30 last night i got sick of being in the house and blah blah blah. went up and fired up the wood stove.....was only like 33 degrees in the shop.
had to jack up my low ass car.....first i had to jack it up a little to put a couple 2x4's under the tire so i could get at the frame rail. lolz
one side up
then i started taking off the old control arm, tension rod, knuckle/hub. noticed the tie rod end was janky so i decided to put my tein tie rods on. i hate inner tie rods. mainly because of lack of confidence since steering is a vital issue.
ran into a problem with the ten inners trying to get my tie rod tool on it. the crows foot doesn't go deep enough to fit it. so i took the bench grinder to it to make it deeper.
success!
then i torqued it on, put on the outer and put the rest of the shit on. s14 knuckles, FLCA, extended studs, uras poly sway endlink bushings, peak performance tension rods, yashio factory core support guards, Z32 26mm front calipers and SS braided conversion lines.
this pic just shows it all mocked up...at about 3:30 the shop had only warmed up to like 46 degrees and my toes were freezing off so i decided just to finder tighten it all and call it a night. now i have to find my luglock key to do the other side. haha
PostSubject: Re: The Unicorn.... The tale of a neverending project....now with more 5 lug.   Mon Mar 05, 2012 3:54 pm
Those were the days. If you aint down with pink, your shit stinks. Haha good luck .
PostSubject: Re: The Unicorn.... The tale of a neverending project....now with more 5 lug.   Thu Mar 08, 2012 8:05 pm
my tomei came today...doesn't really look that much shorter than the ARC.
this pic it looks smaller....but it is just the angle i think.....and my car isn't sitting flat since the front is on jackstands
craftsmanship is what you'd expect from tomei.
no sloshie plates in the arc...it was apparently optional though i guess
yeah...
yeahhhhhhhhh.
PostSubject: Re: The Unicorn.... The tale of a neverending project....now with more 5 lug.   Thu Mar 08, 2012 9:09 pm
Verrrryyyy Niiicee! I love Tomei products. It looks like it is smaller in the pics to me. did you measure it at all? Looks like a solid piece either way.
PostSubject: Re: The Unicorn.... The tale of a neverending project....now with more 5 lug.   Thu Mar 08, 2012 10:04 pm
it is smaller in capacity, but as far as height goes, i'm not sure.....maybe because it isn't as long on the one end that hangs down? that is my only guess. the ARC is forsale if anyone is interested...i am still trying to find the damn hardware for it. i have it somewhere.
Bonin240sx
PostSubject: Re: The Unicorn.... The tale of a neverending project....now with more 5 lug.   Thu Mar 08, 2012 10:20 pm
just read from first to last post! I love cars for this reason...they keep a little piece of you and you just cant give up on them once you find "the one"..good work so far man im glad to see your doing everything you like and could care less what anyone else thinks! good job keep it up and get it done for automotion?
Page 3 of 4Go to page : Previous  1, 2, 3, 4  Next
