 turbo maintanace shop needed
PostSubject: turbo maintanace shop needed   Mon Feb 13, 2012 11:44 pm
i want to know if theres any local shops that do turbo clean ups and rebuild's possibly porting and smoothing the chambers. is this possible?
PostSubject: Re: turbo maintanace shop needed   Tue Feb 14, 2012 12:49 am
no idea about local but a1turbo.net and timsturbos.com are recommended by motor magazine (mechanic trade mag)
PostSubject: Re: turbo maintanace shop needed   Tue Feb 14, 2012 1:01 am
well i found the company that made the turbo im see if the can give it some R/r and do a rebuild and flow bench test to make sure it spools with no issue the turbo it self is fine just needs to be cleaned and resealed had a bit of a leak and lose bolts so i just want to make sure.
PostSubject: Re: turbo maintanace shop needed   Tue Feb 14, 2012 4:34 pm
What brand turbo? You can get rebuild kits to do it yourself just make everything when you take it apart so you reasemble it back in the same place. the balance should be fine on it. And as far as I know the only way to "port/polish" the inside of a turbo is by getting it Extrude honed. Which from what I have read can make a real difference in spool up.
PostSubject: Re: turbo maintanace shop needed   Tue Feb 14, 2012 4:59 pm
im sending it back to garret and there going to do all the rebuild and upgrades its a base to4e model but it seems that garret turbos supplied the body so they will rebuild and upgrade for 215 shipped and the waste gate and bov will go with it to sincro them to 7-10 psi
