 600SX's build - LS2/ T56
Go to page : Previous  1, 2, 3 ... 7, 8, 9, 10, 11  Next
PostSubject: Re: 600SX's build - LS2/ T56   Sat Nov 10, 2012 12:01 pm
nice good luck
PostSubject: Re: 600SX's build - LS2/ T56   Sat Nov 10, 2012 2:18 pm
Started replacing gaskets and found some insight as to the cam in the engine...
I have contacted MTI and am waiting on a response. I can't come up with any other info on the intarwebz for these numbers. Anyone have any ideas?
PostSubject: Re: 600SX's build - LS2/ T56   Sat Nov 10, 2012 8:55 pm
Got the oil pan and rear cover gasket replaced and mocked up the headers to make sure my thread repairs were going to line up.
Comparing the Spec stage 2 clutch to the Monster stage 3 clutch is like apples and oranges, but I did anyway. The Spec 18 lb flywheel is on the left, the Monster 28 lb fw right.
Spec disc left, Monster right.
Pressure plates.
The difference of thickness in the pressure plates is ridiculous.
Now I'm fighting the pilot bearing. It won't come out with the puller I have, so I'm gonna check with Advance or Vato Zone to see if I can rent or buy one in the morning.
ujsp
PostSubject: Re: 600SX's build - LS2/ T56   Sat Nov 10, 2012 11:21 pm
Is the pilot bearing on the LS a similar design to the Nissan stuff? If so, I have seen people have good luck with the "grease trick" or a similar approach.
Like this:
http://www.youtube.com/watch?v=28bSl4r1kwQ
PostSubject: Re: 600SX's build - LS2/ T56   Sun Nov 11, 2012 8:00 am
That doesn't work with an ls. There is a "freeze plug" for lack of a better term behind the pilot bearing, and if you use the grease trick, you run the risk of pushing that out causing a major oil leak.
PostSubject: Re: 600SX's build - LS2/ T56   Sun Nov 11, 2012 8:15 am
So you should have this done just on time for it to be put away for the winter? At least it will be fresh and ready for spring!
PostSubject: Re: 600SX's build - LS2/ T56   Sun Nov 11, 2012 8:28 am
That's my goal.
PostSubject: Re: 600SX's build - LS2/ T56   Mon Nov 12, 2012 11:46 am
Doing a little oogling on the google. I found the MTI V1 cam, which i'm assuming has to be the one in your engine.
http://ls1tech.com/forums/generation-iii-internal-engine/797217-new-mti-v1-cam-afr-heads-results.html
Quote :
Okay I finally got my mods done, I have learned so much on this forum. I thought I would post result here.
This cam is called V1 is a new cam that MTI offers 230/232 592/595 111 lsa
205 afr heads milled to 64
Cometic heads
ported fast
Tex clutch
Tnt 100 shot nos setup(no dynos on this yet.
final numbers 476 hp and 445 tq.
I dont have a ls1 but I learned so much from everyone here. I have c6 vette.
Here are some videos.
While searching the cam specs i came across this video on Youtube.
http://www.youtube.com/watch?v=xJps9-sxnRs
Quote :
06 GTO Cam Only Dyno Pull,
MTI Cam 230 232 111 lsa
Kook's 1 3/4 Long Tube Headers
426 RWHP
06 GTO Cam Dyno Pull kooks headers hp ls2 ls1 v8 muscle cam long tubes mti 06 2006 Run idle
Which sounds pretty damn close to what your car made as well?
PostSubject: Re: 600SX's build - LS2/ T56   Mon Nov 12, 2012 11:49 am
Also here are some pics i took yesterday.
PostSubject: Re: 600SX's build - LS2/ T56   Mon Nov 12, 2012 11:50 am
Almost forgot, Look what was in Captain "Anti-Prius" Driveway.
PostSubject: Re: 600SX's build - LS2/ T56   Mon Nov 12, 2012 12:19 pm
Thanks again to you and Liz for the help, and great pics.
PostSubject: Re: 600SX's build - LS2/ T56   Mon Nov 12, 2012 12:34 pm
Not a problem, looking forward to it being done. Keep me updated on that cam idea.
PostSubject: Re: 600SX's build - LS2/ T56   Mon Nov 12, 2012 8:26 pm
"its not too late for a ka"
PostSubject: Re: 600SX's build - LS2/ T56   Mon Nov 12, 2012 8:30 pm
That'd probably be your only chance of keeping up. geek lol!
PostSubject: Re: 600SX's build - LS2/ T56   Mon Nov 12, 2012 10:49 pm
haha ohhh thats right, we aren't at the dinner table anymore ;-)
PostSubject: Re: 600SX's build - LS2/ T56   Tue Nov 13, 2012 6:53 am
You know I'm kidding. I'll go on record and say I think your car will be hard to beat.
PostSubject: Re: 600SX's build - LS2/ T56   Tue Nov 13, 2012 9:36 pm
ill go on the record and say i dont think so. but it doesnt matter, b/c either way we both get icecream!!!! Smile
ujsp
PostSubject: Re: 600SX's build - LS2/ T56   Tue Nov 13, 2012 11:23 pm
On a serious note, your still using the T56 right? So that bell-housing is just a stronger piece made to protect you and the car in the case of a high-rpm clutch catastrophe, not for the purpose of mating to a different trans, correct? Just curious.
I love the V8 swap idea. The more I look into it, the more of a "no-brainer" option it is. Especially since the "baby sized" 4.8/5.3 L can be had for super cheap. Obviously you went the big boy route, which is even better! haha
Any future plans for the powertrain? Nitrous, other FI? Is the stock diff sufficient to hold the torque that thing makes?
PostSubject: Re: 600SX's build - LS2/ T56   Wed Nov 14, 2012 12:04 am
That's a good question, i don't even know what Diff he has in the car. lol
PostSubject: Re: 600SX's build - LS2/ T56   Wed Nov 14, 2012 7:01 am
That is exactly correct. Not that ~550 bhp is enough to break anything that badly, but I like my feet. The stock bellhousing you could lift with one finger, the quick time is about 30 lbs.
No nos, maybe a centrifugal super or rear mounted turbo wayyyyy down the line.
The diff is stock and has given me no problems as of yet, and I beat it like a red-headed step child.
PostSubject: Re: 600SX's build - LS2/ T56   Wed Nov 14, 2012 5:42 pm
Nice to see your car coming back together! I look forward to hearing it on the road again!
PostSubject: Re: 600SX's build - LS2/ T56   Wed Nov 14, 2012 5:45 pm
WTF?? DUH, It's a hybrid, they're supposed to be silent. rofl
I just got a new signature idea...
BOOM. Fixed.
Last edited by 600SX on Wed Nov 14, 2012 5:49 pm; edited 1 time in total (Reason for editing : Sig)
PostSubject: Re: 600SX's build - LS2/ T56   Wed Nov 21, 2012 6:54 pm
More of your truck.
PostSubject: Re: 600SX's build - LS2/ T56   Wed Nov 21, 2012 7:01 pm
77 wrote:
More of your truck.
I can if you want, but it's pretty boring compared to the car.
Speaking of the car, IT RAN TONIGHT! Nick heard it, I had to call him.
PostSubject: Re: 600SX's build - LS2/ T56   Thu Nov 22, 2012 11:33 am
That is awesome! It's about time.
Page 8 of 11Go to page : Previous  1, 2, 3 ... 7, 8, 9, 10, 11  Next
