 RB20det help asap
downwiththeRB
PostSubject: RB20det help asap   Sat Feb 18, 2012 1:11 am
hey i'm currently puting a new head on my rb20 i have arp head bolts they told me to torque to 80ft lbs does that sound right?.. then my second question is i nee the torque spec for the cam cap bolts and tightening sequence i need the spec in ft lbs... i can find them in nm idk what that is and this is the part where i'm stumped.. i could really use some help asap please thanks.......
PostSubject: Re: RB20det help asap   Sat Feb 18, 2012 6:01 am
If the spec is 80 ft lbs, torque them to that. Use the torque sequence that you should be able to find in the RB service manual.
Most torque wrenches will have NM as well as FT LBS stamped right on them. If not, use a unit converter... The interwebs is a magical place.
PostSubject: Re: RB20det help asap   Sat Feb 18, 2012 10:24 am
I love me the interwebs. Such a magical place with unicorns an stuff
PostSubject: Re: RB20det help asap   Sat Feb 18, 2012 11:10 am
Try this...
PostSubject: Re: RB20det help asap   Sat Feb 18, 2012 11:12 am
80 ft lbs is with the arp moly lube stuff. if you don't have any of that you can use motor oil but it has a different tq spec.
downwiththeRB
PostSubject: Re: RB20det help asap   Sat Feb 18, 2012 3:10 pm
what should i torque the cam caps to????
PostSubject: Re: RB20det help asap   Sat Feb 18, 2012 6:08 pm
Look in the RB service manual, It's stickied somewhere.
RB20det help asap
