 injector recommendations
airman240
PostSubject: injector recommendations   Sat Feb 18, 2012 3:05 pm
I have an SR20det and just got a precision 6152e turbo for it, just askin around to see if anyone has any rec. on brand/size? thanks
PostSubject: Re: injector recommendations   Sun Feb 19, 2012 10:38 pm
nothing smaller than 740's Thats a lot of turbo for an sr. Are you bone stock still?
PostSubject: Re: injector recommendations   Mon Feb 20, 2012 9:30 am
I agree. somewhere in the 740+ area, don't go too big though depending on what tuning software you have as sometimes it's hard for bigger injectors to idle.
airman240
PostSubject: Re: injector recommendations   Mon Feb 20, 2012 6:23 pm
I have apexi power command for tuning. So 850 would work good enough?Someone told me 1000 but I thought that was a little high for that setup.
PostSubject: Re: injector recommendations   Mon Feb 20, 2012 7:09 pm
Thats a big turbo, 1000s probably wouldnt be way over kill but again, BE CAREFUL with that size turbo on stock internals. Your not going to enjoy the lag, and it will be very easy for it to get out of control and blow your sr sky high.
PostSubject: Re: injector recommendations   Tue Feb 21, 2012 9:26 am
Sounds like you have an apexi power FC. My car idles fine on 1,200cc injectors.
airman240
PostSubject: Re: injector recommendations   Tue Feb 21, 2012 5:49 pm
thanks for the info -240sxguy-, what brand are you using?
PostSubject: Re: injector recommendations   Tue Feb 21, 2012 7:25 pm
I am using a low impedance bosch injector I bought off of ebay. The injector spray pattern isn't the best but they seem to do fine for my application.
Evan
