 PCB based fuse/relay bank?
PostSubject: PCB based fuse/relay bank?   Wed Mar 07, 2012 6:38 pm
I love the concept of the FZ1, which is a simple, lightweight fuse block to control +12V hot and switched circuits in a tidy manner.
Has anyone ever run into any similar products available with an integrated relay or two to switch an external device on?
I am looking for something to compactly and cleanly handle basic headlight, tail light, reverse light, cluster, and turn signal power along with headlight and ECU relays.
PostSubject: Re: PCB based fuse/relay bank?   Wed Mar 07, 2012 6:38 pm
If I could find a "deluxe" FZ1 that was rated for greater power draw and had two replaceable relays integrated that would be perfect. If I am going as far as mounting external relays separate from the board then I think I will just rewire everything with a much cheaper blue sea fuse block.
I did find this unit which has nearly all of the features I am looking for. It doesn't list safe working amperage though. Check out the relay mounted for the horn and the on board turn signal/hazard relays, this is a step in the right direction.
Compact, less than 1lb, and it has a fairly simple layout. Smile
I am going to look into having my own PCB made and built up for my specs, then I can get exactly what I need for my system.
PostSubject: Re: PCB based fuse/relay bank?   Wed Mar 07, 2012 10:10 pm
They are pretty proud of that thing for $135. With what you are doing, I wouldn't screw with an off the shelf setup. Just make exactly what you need. I would pass on a PCB setup just because the amperage rating reasons. Also, I suspect a purpose built fuse box is going to be more long term durable. Make sure you can expand it if you need to as well.
PostSubject: Re: PCB based fuse/relay bank?   Thu Mar 08, 2012 1:29 am
Not knowing anything about anything, this was my concern. I got pretty excited the first time I saw a how-to on making your own board.
I get pretty excited now when I see a thread with Speed making his own stuff. That's my intention of "building cars" at least, to learn.
Qfabbed
PostSubject: Re: PCB based fuse/relay bank?   Mon Mar 19, 2012 2:45 am
Unless you're planning to run a carbureted V8, that isn't nearly enough to run a car, much less EFI, headlights, taillights, etc. Whenever I build harnesses for drift cars/street cars, I use the factory fuseboxes and strip them down to the bare minimum to keep all of the AMP ratings correct for the electrical system. That, and diagnosis/repair is a breeze if necessary.
