 rb20 question
downwiththeRB
PostSubject: rb20 question   Sat Mar 31, 2012 2:20 am
so i almosy got my rb20 back together.. its stock for the most part im looking for some quick ways to get some power out of it???? it feels sluggish ill rool at like 35 and punch it and ill mabye hit 6 lbs before i gotta shift and when i do it in 3rd i can hit 10.. i just need some quick ideas on how to bump it up a lil bit??? also those little metal covers above the cams that bolt to the cam caps are those necesary?? so let me know i could use little extra power
PostSubject: Re: rb20 question   Sat Mar 31, 2012 12:42 pm
Manual boost controller will help you make more boost in lower gears. Yes you need the baffles unless you like oil spraying out the PCV system. I have a MBC here I don't need anymore if you need one. It's a grimmspeed.
downwiththeRB
PostSubject: Re: rb20 question   Sat Mar 31, 2012 1:42 pm
i got a manual boost controller on it and its all the way open it takes so long to build boost tho
PostSubject: Re: rb20 question   Sat Mar 31, 2012 4:06 pm
What size turbo are you running? If it is big it will take a long time to spool up.
PostSubject: Re: rb20 question   Sat Mar 31, 2012 4:54 pm
Cam timing could be off, that's not normal.
rb20 question
